I have the following schematic with 2 opamp. I have to do a transient analysis and eventually find the slew rate of the opamp. My simulation parameters are:
  • Run to time: 1ms
  • Step size: 1us
schematics
error
Any suggestions on how to fix it ?
  • \$\begingroup\$ Sorry, I don't have PSpice, but here's a a couple generic SPICE suggestions. (1) Try different opamps. (2) Increase TR and TF of the pulse source. (3) Add a small series resistor (10mohm to 100mohm) between the supply voltages and VCC/VEE nodes and also 100nF capacitors to ground on those nodes. \$\endgroup\$
    – Ste Kulov
    Commented Oct 14, 2020 at 11:20
    \$\begingroup\$ pay attention to a "ground" node at Vcc/Vee generation network, to the left of your schematic. Ref.: pspice.com/… \$\endgroup\$
    – V.V.T
    Commented Oct 14, 2020 at 11:49
I fixed it. My problem coming from the wrong GND on the left of my schematic. Link
    \$\begingroup\$ You may have used your hands to fix it, but the insight came from V.V.T's comment. At any rate, you can check your answer. \$\endgroup\$ Commented Oct 14, 2020 at 17:41
