for my project, I have decided to use STUSB4500 for negotiating 20V for powering external remotely controlled LED lighting.
My circuit design comes from the minimum implementation in the datasheet, but I've decided to get rid of the p-Mosfet as I don't need on/off switch on the sink. I believe that the negotiation is happening on the CC lines, so hopefully, this decision shouldn't interfere.
A very similar circuit is used in the fpx module, as well as in the SparkFun Power Delivery Board. Both of them have the p-Mosfets included, however.
Here is the relevant part of my schematic:
The whole schematic is available here, if needed.
I am unable to negotiate any voltage above 5V. I've tried to use both factory settings of the chip and also programming the NVM contents by myself.
The SparkFun board is working as expected with the same USB adapter. The schematic looks pretty similar apart from the mentioned p-MOSFET:
According to the datasheet, the VBUS_EN_SNK
pin is an open-drain which I believe could even be left unconnected.
The NVRAM content I tried is the following (default configuration in the Sparkfun library):
uint8_t sector[5][8] =
{0x00,0x00,0xB0,0xAA,0x00,0x45,0x00,0x00},
{0x10,0x40,0x9C,0x1C,0xFF,0x01,0x3C,0xDF},
{0x02,0x40,0x0F,0x00,0x32,0x00,0xFC,0xF1},
{0x00,0x19,0x56,0xAF,0xF5,0x35,0x5F,0x00},
{0x00,0x4B,0x90,0x21,0x43,0x00,0x40,0xFB}
As a guide for understanding the NVRAM content, the relevant parts of the SparkFun library could be used.
I've already inspected the board for soldering problems and tried four different pieces. Any ideas on what could be wrong or how to debug power delivery communication?
Is there any other purpose for the original MOSFET, other than switching on and off the external device?
Thanks!
usb c trigger module
...duckduckgo.com/… \$\endgroup\$
