I want to organize a USB stick based on STM32F105RBT + AT45DB041. Problem: after reconnecting the device to a PC, windows7 asks to format the disk.
Problem identification algorithm:
  1. Connect to PC
  2. Format the USB flash drive (formatting is completed successfully)
  3. Write any file to a USB flash drive
  4. Disconnect the USB flash drive from the PC
  5. Connect device to PC Result: Windows asks to format the USB flash drive
Everything works fine if: Size of file (-files) <= 12KB (After reconnecting the USB flash drive to the PC, the file opens successfully, the data is not damaged)
SPI memory AT45DB041 has a total of 2048 pages of 264 bytes each. Writing / reading is performed at 256 bytes per page. Writing a 512 byte block requires two pages of memory.
I am sure that the problem is in the procedure for erasing memory sectors, in the STORAGE_Write_FS function, but I don’t understand where I went wrong?
    int8_t STORAGE_Write_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len)
      /* USER CODE BEGIN 7 */
      AT45dbxx_ErasePage(blk_addr*2);
      AT45dbxx_ErasePage(blk_addr*2+1);
      AT45dbxx_WritePage(buf, 256, (uint16_t)blk_addr*2);
      AT45dbxx_WritePage(buf+256, 256, (uint16_t)blk_addr*2+1);
      return (USBD_OK);
      /* USER CODE END 7 */
void AT45dbxx_ErasePage(uint16_t page)
    page = page << AT45dbxx.Shift; // AT45dbxx.Shift = 9 For 264 byte per page
    AT45dbxx_Resume();
    AT45dbxx_WaitBusy();
    HAL_GPIO_WritePin(_45DBXX_CS_GPIO,_45DBXX_CS_PIN,GPIO_PIN_RESET);
    AT45dbxx_Spi(AT45DB_PGERASE); // CMD 0x81
    AT45dbxx_Spi((page >> 16) & 0xff);
    AT45dbxx_Spi((page >> 8) & 0xff);
    AT45dbxx_Spi(page & 0xff);
    HAL_GPIO_WritePin(_45DBXX_CS_GPIO,_45DBXX_CS_PIN,GPIO_PIN_SET);
void AT45dbxx_WritePage(uint8_t *Data,uint16_t len,uint16_t page)
    AT45dbxx_Resume();
    AT45dbxx_Spi(AT45DB_MNTHRUBF1);  // CMD 0x82
    HAL_SPI_Transmit(&_45DBXX_SPI,Data,len,100);
Functions for working with memory work correctly in the entire range of pages. The flash drive is formatted using windows before recording.
    \$\begingroup\$ If you look at the disk image, you might be able to see what type of corruption is happening. (I recommend using HxD, a hex editor which can directly show you the bytes on a disk) \$\endgroup\$
    – user253751
    Oct 15, 2020 at 10:20
    \$\begingroup\$ @user253751,Thanks for the recommendation to use HxD \$\endgroup\$
    – Chip115
    Oct 15, 2020 at 12:17
    \$\begingroup\$ So it seems to me that your testing will not catch an issue where something goes wrong with addressing. What happens if there's a situation where the memory device always sees one of the address bit values stuck low (maybe there's a problem with the way you're sending the address to the device). You think you're writing & reading pages 0, 1, 2, 3, 4, 5, 6, 7, 8 - but say bit 2 is stuck low - then you'll actually be writing pages 0, 1, 2, 3, 0, 1, 2, 3 - your test won't catch that. But this kind of thing is exactly what could cause the symptoms you're seeing. \$\endgroup\$
    – brhans
    Oct 15, 2020 at 13:01
  • 4
    \$\begingroup\$ Your page parameter is a uint_16, but you're shifting it left 9 bits. You're effectively reducing your page address down to 7 bits. 128 pages x 256 bytes == 32k. Assuming your filesystem takes 20k of overhead (FAT tables) then once you write more than 12k to a file you'll wrap around and start overwriting the filesystem stuff and windows then will want to reformat it... \$\endgroup\$
    – brhans
    Oct 15, 2020 at 13:09
    \$\begingroup\$ @brhans Yes you are right. I fixed uint16_t to uint32_t and it worked. Thanks! \$\endgroup\$
    – Chip115
    Oct 15, 2020 at 13:51
I fixed uint16_t page to uint32_t page and it worked. Thanks!
void AT45dbxx_ErasePage(uint32_t page)
    AT45dbxx_Resume();
void AT45dbxx_WritePage(uint8_t *Data,uint16_t len,uint32_t page)
    AT45dbxx_Resume();
