-10
I have generated single port RAM (DP8KC primitive) from IP express using Lattice tool and then I am instantiating with 48 bit shift register, which is at input side. The output of shift register is connected to ram side in order to save write data from shift register. Then from RAM, I have to out data on mach x02 board. But I am getting error while synthesizing in lattice tool.
.ERROR-@E: Net "sout[0]" in work.grayscale(verilog) has conflicting drivers, the connections are
@E: BN314 :"d:\led_project\program\tlc\sim\tlc\source\tlc.v":1:7:1:15|Net "sout[0]" in work.grayscale(verilog) has multiple drivers
also help me that can i directly connect output of ram with board and how to connect ?and out of ram should be instantiated with design or other module? Is it a good practice to read write 48 bits data in 1 row and then read ie to display led on board? Please suggest me with correct code.
Shift register design (Verilog code)
module grayscale(s_in,gsclk,dcsel,xlat,blank,lod,tef,cs,sout,ch_out,sclk,xerr);
  input s_in,gsclk,dcsel,xlat,blank,lod,tef,sclk;
   input [1:0] cs;
   output xerr;
   output [47:0]sout;
   output [15:0] ch_out;
   reg [5:0]     counter_q;
   reg [47:0]    temp;
   wire [1:0] cs;
  /*constant declarations for chip select */
`define  cs1 2'b00
`define  cs2 2'b01
`define  cs3 2'b10
   assign  xerr = (lod |tef) ? 1'b0 :
                     1'b1;
   assign  gs_enable = (~dcsel& sclk==1'b1) ? 1'b1:
                       1'b0;
   assign gs_int_cnt = (~blank & gsclk==1'b1) ? 1'b1:
               1'b0;
    assign ch_out = (`cs1==cs) ? temp[15:0]: ((`cs2==cs) ? temp[31:16] : temp[47:32]);
  /* assign ch_out = (`cs1==cs) ? sout[15:0]:
           (`cs2==cs) ? sout[16:31]: sout[32:47];*/
/* parameterized module instance */
shift_ram grayscale (.Clock(gsclk ), .ClockEn(1'b1 ), .Reset(1'b0 ), .WE(1'b1 ), .Address(2'b00 ),
    .Data(s_in ), .Q(sout ));
always@( posedge gsclk)
  begin
     if(gs_enable==1'b1)
      temp <= {temp[46:0],s_in};
     else
       temp <= 47'b0;
  end
     assign sout = temp;
always@(posedge gsclk)
begin
if(blank==1'b0)
  counter_q <= counter_q + 1'b1;
else
  counter_q <= 6'b0;
end
endmodule
RAM code generated from IP express
/* Verilog netlist generated by SCUBA Diamond_2.0_Production (151) */
/* Module Version: 7.1 */
/* C:\lscc\diamond\2.0\ispfpga\bin\nt\scuba.exe -w -lang verilog -synth synplify -bus_exp 7 -bb -arch xo2c00 -type bram -wp 10 -rp 1000 -addr_width 2 -data_width 48 -num_rows 4 -cascade -1 -mem_init0 -writemode NORMAL -e  */
/* Wed Jan 02 21:24:28 2013 */
`timescale 1 ns / 1 ps
module shift_ram (Clock, ClockEn, Reset, WE, Address, Data, Q);
    input wire Clock;
    input wire ClockEn;
    input wire Reset;
    input wire WE;
    input wire [1:0] Address;
    input wire [47:0] Data;
    output wire [47:0] Q;
    wire scuba_vhi;
    wire scuba_vlo;
    defparam shift_ram_0_0_2.INIT_DATA = "STATIC" ;
    defparam shift_ram_0_0_2.ASYNC_RESET_RELEASE = "SYNC" ;
    defparam shift_ram_0_0_2.INITVAL_1F = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_1E = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_1D = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_1C = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_1B = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_1A = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_19 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_18 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_17 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_16 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_15 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_14 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_13 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_12 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_11 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_10 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_0F = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_0E = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_0D = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_0C = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_0B = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_0A = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_09 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_08 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_07 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_06 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_05 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_04 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_03 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_02 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_01 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.INITVAL_00 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_0_2.CSDECODE_B = "0b000" ;
    defparam shift_ram_0_0_2.CSDECODE_A = "0b000" ;
    defparam shift_ram_0_0_2.WRITEMODE_B = "NORMAL" ;
    defparam shift_ram_0_0_2.WRITEMODE_A = "NORMAL" ;
    defparam shift_ram_0_0_2.GSR = "ENABLED" ;
    defparam shift_ram_0_0_2.RESETMODE = "ASYNC" ;
    defparam shift_ram_0_0_2.REGMODE_B = "NOREG" ;
    defparam shift_ram_0_0_2.REGMODE_A = "NOREG" ;
    defparam shift_ram_0_0_2.DATA_WIDTH_B = 9 ;
    defparam shift_ram_0_0_2.DATA_WIDTH_A = 9 ;
    DP8KC shift_ram_0_0_2 (.DIA8(Data[8]), .DIA7(Data[7]), .DIA6(Data[6]),
        .DIA5(Data[5]), .DIA4(Data[4]), .DIA3(Data[3]), .DIA2(Data[2]),
        .DIA1(Data[1]), .DIA0(Data[0]), .ADA12(scuba_vlo), .ADA11(scuba_vlo),
        .ADA10(scuba_vlo), .ADA9(scuba_vlo), .ADA8(scuba_vlo), .ADA7(scuba_vlo),
        .ADA6(scuba_vlo), .ADA5(scuba_vlo), .ADA4(Address[1]), .ADA3(Address[0]),
        .ADA2(scuba_vlo), .ADA1(scuba_vlo), .ADA0(scuba_vhi), .CEA(ClockEn),
        .OCEA(ClockEn), .CLKA(Clock), .WEA(WE), .CSA2(scuba_vlo), .CSA1(scuba_vlo),
        .CSA0(scuba_vlo), .RSTA(Reset), .DIB8(Data[17]), .DIB7(Data[16]),
        .DIB6(Data[15]), .DIB5(Data[14]), .DIB4(Data[13]), .DIB3(Data[12]),
        .DIB2(Data[11]), .DIB1(Data[10]), .DIB0(Data[9]), .ADB12(scuba_vhi),
        .ADB11(scuba_vlo), .ADB10(scuba_vlo), .ADB9(scuba_vlo), .ADB8(scuba_vlo),
        .ADB7(scuba_vlo), .ADB6(scuba_vlo), .ADB5(scuba_vlo), .ADB4(Address[1]),
        .ADB3(Address[0]), .ADB2(scuba_vlo), .ADB1(scuba_vlo), .ADB0(scuba_vhi),
        .CEB(ClockEn), .OCEB(ClockEn), .CLKB(Clock), .WEB(WE), .CSB2(scuba_vlo),
        .CSB1(scuba_vlo), .CSB0(scuba_vlo), .RSTB(Reset), .DOA8(Q[8]), .DOA7(Q[7]),
        .DOA6(Q[6]), .DOA5(Q[5]), .DOA4(Q[4]), .DOA3(Q[3]), .DOA2(Q[2]),
        .DOA1(Q[1]), .DOA0(Q[0]), .DOB8(Q[17]), .DOB7(Q[16]), .DOB6(Q[15]),
        .DOB5(Q[14]), .DOB4(Q[13]), .DOB3(Q[12]), .DOB2(Q[11]), .DOB1(Q[10]),
        .DOB0(Q[9]))
             /* synthesis MEM_LPC_FILE="shift_ram.lpc" */
             /* synthesis MEM_INIT_FILE="INIT_ALL_0s" */;
    defparam shift_ram_0_1_1.INIT_DATA = "STATIC" ;
    defparam shift_ram_0_1_1.ASYNC_RESET_RELEASE = "SYNC" ;
    defparam shift_ram_0_1_1.INITVAL_1F = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_1E = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_1D = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_1C = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_1B = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_1A = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_19 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_18 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_17 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_16 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_15 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_14 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_13 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_12 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_11 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_10 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_0F = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_0E = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_0D = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_0C = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_0B = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_0A = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_09 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_08 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_07 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_06 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_05 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_04 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_03 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_02 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_01 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.INITVAL_00 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_1_1.CSDECODE_B = "0b000" ;
    defparam shift_ram_0_1_1.CSDECODE_A = "0b000" ;
    defparam shift_ram_0_1_1.WRITEMODE_B = "NORMAL" ;
    defparam shift_ram_0_1_1.WRITEMODE_A = "NORMAL" ;
    defparam shift_ram_0_1_1.GSR = "ENABLED" ;
    defparam shift_ram_0_1_1.RESETMODE = "ASYNC" ;
    defparam shift_ram_0_1_1.REGMODE_B = "NOREG" ;
    defparam shift_ram_0_1_1.REGMODE_A = "NOREG" ;
    defparam shift_ram_0_1_1.DATA_WIDTH_B = 9 ;
    defparam shift_ram_0_1_1.DATA_WIDTH_A = 9 ;
    DP8KC shift_ram_0_1_1 (.DIA8(Data[26]), .DIA7(Data[25]), .DIA6(Data[24]),
        .DIA5(Data[23]), .DIA4(Data[22]), .DIA3(Data[21]), .DIA2(Data[20]),
        .DIA1(Data[19]), .DIA0(Data[18]), .ADA12(scuba_vlo), .ADA11(scuba_vlo),
        .CSA0(scuba_vlo), .RSTA(Reset), .DIB8(Data[35]), .DIB7(Data[34]),
        .DIB6(Data[33]), .DIB5(Data[32]), .DIB4(Data[31]), .DIB3(Data[30]),
        .DIB2(Data[29]), .DIB1(Data[28]), .DIB0(Data[27]), .ADB12(scuba_vhi),
        .CSB1(scuba_vlo), .CSB0(scuba_vlo), .RSTB(Reset), .DOA8(Q[26]),
        .DOA7(Q[25]), .DOA6(Q[24]), .DOA5(Q[23]), .DOA4(Q[22]), .DOA3(Q[21]),
        .DOA2(Q[20]), .DOA1(Q[19]), .DOA0(Q[18]), .DOB8(Q[35]), .DOB7(Q[34]),
        .DOB6(Q[33]), .DOB5(Q[32]), .DOB4(Q[31]), .DOB3(Q[30]), .DOB2(Q[29]),
        .DOB1(Q[28]), .DOB0(Q[27]))
    VHI scuba_vhi_inst (.Z(scuba_vhi));
    VLO scuba_vlo_inst (.Z(scuba_vlo));
    defparam shift_ram_0_2_0.INIT_DATA = "STATIC" ;
    defparam shift_ram_0_2_0.ASYNC_RESET_RELEASE = "SYNC" ;
    defparam shift_ram_0_2_0.INITVAL_1F = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_1E = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_1D = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_1C = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_1B = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_1A = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_19 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_18 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_17 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_16 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_15 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_14 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_13 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_12 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_11 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_10 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_0F = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_0E = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_0D = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_0C = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_0B = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_0A = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_09 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_08 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_07 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_06 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_05 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_04 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_03 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_02 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_01 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.INITVAL_00 = "0x00000000000000000000000000000000000000000000000000000000000000000000000000000000" ;
    defparam shift_ram_0_2_0.CSDECODE_B = "0b000" ;
    defparam shift_ram_0_2_0.CSDECODE_A = "0b000" ;
    defparam shift_ram_0_2_0.WRITEMODE_B = "NORMAL" ;
    defparam shift_ram_0_2_0.WRITEMODE_A = "NORMAL" ;
    defparam shift_ram_0_2_0.GSR = "ENABLED" ;
    defparam shift_ram_0_2_0.RESETMODE = "ASYNC" ;
    defparam shift_ram_0_2_0.REGMODE_B = "NOREG" ;
    defparam shift_ram_0_2_0.REGMODE_A = "NOREG" ;
    defparam shift_ram_0_2_0.DATA_WIDTH_B = 9 ;
    defparam shift_ram_0_2_0.DATA_WIDTH_A = 9 ;
    DP8KC shift_ram_0_2_0 (.DIA8(Data[44]), .DIA7(Data[43]), .DIA6(Data[42]),
        .DIA5(Data[41]), .DIA4(Data[40]), .DIA3(Data[39]), .DIA2(Data[38]),
        .DIA1(Data[37]), .DIA0(Data[36]), .ADA12(scuba_vlo), .ADA11(scuba_vlo),
        .CSA0(scuba_vlo), .RSTA(Reset), .DIB8(scuba_vlo), .DIB7(scuba_vlo),
        .DIB6(scuba_vlo), .DIB5(scuba_vlo), .DIB4(scuba_vlo), .DIB3(scuba_vlo),
        .DIB2(Data[47]), .DIB1(Data[46]), .DIB0(Data[45]), .ADB12(scuba_vhi),
        .CSB1(scuba_vlo), .CSB0(scuba_vlo), .RSTB(Reset), .DOA8(Q[44]),
        .DOA7(Q[43]), .DOA6(Q[42]), .DOA5(Q[41]), .DOA4(Q[40]), .DOA3(Q[39]),
        .DOA2(Q[38]), .DOA1(Q[37]), .DOA0(Q[36]), .DOB8(), .DOB7(), .DOB6(),
        .DOB5(), .DOB4(), .DOB3(), .DOB2(Q[47]), .DOB1(Q[46]), .DOB0(Q[45]))
    // exemplar begin
    // exemplar attribute shift_ram_0_0_2 MEM_LPC_FILE shift_ram.lpc
    // exemplar attribute shift_ram_0_0_2 MEM_INIT_FILE INIT_ALL_0s
    // exemplar attribute shift_ram_0_1_1 MEM_LPC_FILE shift_ram.lpc
    // exemplar attribute shift_ram_0_1_1 MEM_INIT_FILE INIT_ALL_0s
    // exemplar attribute shift_ram_0_2_0 MEM_LPC_FILE shift_ram.lpc
    // exemplar attribute shift_ram_0_2_0 MEM_INIT_FILE INIT_ALL_0s
    // exemplar end
endmodule
    \$\begingroup\$ It is a pretty messy question, @Manzer - try and make it a bit more coherent next time (or you can edit and tidy this one up a bit) \$\endgroup\$ – Oli Glaser Jan 2 '13 at 18:47
  • \$\begingroup\$ Is there any way we can disable this guy's caps lock or shift key? :D \$\endgroup\$ – Gustavo Litovsky Jan 2 '13 at 19:47
    \$\begingroup\$ I've edited your post (where I could) to make it look more like a question and less like a stream of consciousness. \$\endgroup\$ – Nick Alexeev Jan 2 '13 at 20:44
7
Your error message is telling you that sout is being driven by multiple drivers, which will cause a conflict.
Having a very quick scan through the code (I haven't looked to see what you are trying to do), I can see you assign sout to temp underneath your first always block, and also you have it connected to the Q output of the shift_ram module. Disconnect one of these and the error should go away.
