Probably not the best place to ask this question, I'll remove it if not received well.
I am trying to perform EMI/EMC analysis of my resonant buck converter PCB. I tried to use ANSYS SIwave for this, but I'm not able to find much documentation on it to clarify my specific doubts, I even tried asking it here before. Does anyone have any suggestions as to what software I could use for this? I'm nor currently in a position to perform hardware tests due to the pandemic.
  • \$\begingroup\$ Does anyone have any suggestions as to what software I could use for this? Asking for products is Off-Topic here. What works for me might not work for you. \$\endgroup\$ Oct 16, 2020 at 9:47
  • \$\begingroup\$ Your Y axis seems to be dB, which is a unit of power. You might like to see a dB vs V vs Frequency table at the end of my answer to the following Q&A: DIY Rpi Triple Axis RF / EMF Detector using AD8362 / AD8361 - EESE 2020may21 raspberrypi.stackexchange.com/questions/112643/…. The Wiki on dB might also help: en.wikipedia.org/wiki/Decibel. Cheers. \$\endgroup\$
    – tlfong01
    Oct 16, 2020 at 9:51
  • \$\begingroup\$ @Bimpelrekkie I wasn't "asking for products" I just wanted to know what other software like SIWave could be used, I haven't done this before, and SIWave seems to be a bit complex,thank you for your comment. \$\endgroup\$
    – SM32
    Oct 16, 2020 at 18:35
