I am designing a new project which demands the usage of DRAM. I have never interfaced with one before, so my knowledge is rather limited. By analyzing the requirements, it would be sufficient to go with a 128 Mbit capacity running at 100 MHz with a 16 bit transfer per cycle.
By doing the research, I concluded that a SDR DRAM should be my choice for the following reasons:
  • The controller is simpler to implement (I am aware that there are controllers available and also vendors may provide their own, but I may implement my own for learning purposes)
  • It is good entry level for DRAM
  • It does not need dedicated FPGA pins, so more flexibility
  • The PCB layout is simpler due to the single ended, 50 Ohm impedance traces, versus the differential of the DDR
  • A 16-bit SDR bus has the same number of traces as the 8 bit DDR, so no saving on this
  • It uses 3.3V so I don't have to mess with different voltages on the banks (vs the SSTL of DDR)
  • A SDR is cheaper than DDR
  • Power consumption is lower in DDR, but the SDR consumption is not prohibitive or excessive
Now, based on the above, is there a major reason which I am not aware and have not considered that I should prefer going with DDR instead?
  • \$\begingroup\$ Personally, I would prefer DDR for the vastly improved bandwidth (I do a lot of HD video processing), but I have a client that wants to use a small "pseudo-SRAM" (actually DRAM inside) with an SDR interface, the Alliance AS1C8M16PL-70BIN. It comes in speed grades up to 133 MHz (burst mode), and is much lower power than most DDR SDRAM, along with all of the other advantages you list. \$\endgroup\$
    – Dave Tweed
    Oct 19, 2020 at 22:58
This seems like an XY problem.
Nevertheless, I'll answer:
  • DDR DRAM part types are more available (SDR is becoming / has become obsolete)
  • SDR is not cheaper. Not on a per-bit or per-device basis. It's considered specialty now.
  • You still need to route carefully for timing reasons, be it SDR or DDR
  • DDR uses source-sync timing which is much easier to meet. SDR uses system-sync, which faces skew problems
  • Lower power (DDR is made on smaller device nodes than SDR)
  • Available reference designs (Zynq, etc.) use DDR.
As far as the I/O voltage, it's not such a big deal to place the DRAM pins on the appropriate banks (e.g., 1.8V for DDR2) and power them separately. Suitable DCDC regulator ICs for this are very cheap (1-2A, less than 10 cents in volume).
And differential routing should not be a stumbling block. This only affects DQS and CLK. That's two pairs. In return you get better timing.
