Edit: setting the Wait time to 0.1 causes it to make music, yay?
I've managed to get the steppers to react to xSTP with this code:
#include "mbed.h"
DigitalOut xEN(P2_1); //Pin 74 of LPC
DigitalOut xSTP(P2_2); //Pin 73 of LPC
DigitalOut xDIR(P2_6); //Pin 67 of LPC
//DigitalOut yEN(P2_8); //Pin 65 of LPC
//DigitalOut ySTP(P0_19); //Pin 59 of LPC
//DigitalOut yDIR(P0_20); //Pin 58 of LPC
int main() {
xDIR = 0;
xEN = 0;
for(int i = 0; i < 100; i++){
        xSTP = 1;
        wait(1);
        xSTP = 0;
        wait(1);
but now the motor just holds torque, but don't move. It does however make a slight vibration every 1 second though
I'm trying to get the SKR V1.3 board here: https://github.com/bigtreetech/BIGTREETECH-SKR-V1.3/blob/master/BTT%20SKR%20V1.3/hardware/SKR-V1.3-SCH.pdf
to send 1 second pulses on xSTP and ySTP to get my stepper motors moving, using the MBED framework's LPC1768 pin definitions. They work with Merlin G-code instructions but im trying to get them to work with mbed. Is there something im missing?
    \$\begingroup\$ How about you temporarily start over with an empty program, disconnect the stepper driver, and just try to make those GPIOs both blip on and off at a slow enough rate that you can tell they are working with an LED or multimeter or whatever test equipment you have handy (eg, a scope would be great if you have one, but...) \$\endgroup\$ – Chris Stratton Oct 19 '20 at 22:38
  • \$\begingroup\$ Why did you remove the firmware and micro controller tag? This involves the LPC1768 chip. \$\endgroup\$ – dragonking3002 Oct 20 '20 at 19:44
  • \$\begingroup\$ That this involves firmware or a microcontroller is useless and thus merely tag pollution - why would anyone reading those tags be interested in this question? Your issue is perhaps with a stepper motor, but really with not understanding how to get mbed style program to do what you want, so those are the tags that are possibly meaningful. \$\endgroup\$ – Chris Stratton Oct 21 '20 at 18:53
The awnser was much simpler then expected....
I felt the steppers move very very slightly when I first turned them on so I set the wait interval to 0.001 instead of 1 to see if that was the problem and the steppers now spin without issue........
#include "mbed.h"
int main() {
xDIR = 0;
xEN = 0;
for(int i = 0; i < 20000; i++){
        xSTP = 1;
        wait(0.001);
        xSTP = 0;
        wait(0.001);
