SSR Latch Circuit
Is there any issue with connecting the output of an SSR back to its input to implement latching functionality as in the diagram? I've searched but can't find anything that says definitively whether this is an acceptable or unacceptable configuration. U1 is a Sensata-Crydom Power Plus DC SSR with 1-60VDC operating voltage and 4-32VDC control voltage (internally current limited but not shown in symbol). D1 prevents the 28V load supply voltage from shorting into the (non-isolated) 24V control voltage when SW1 is pressed, D2 prevents control voltage from trying to power the load. The goal is to have the load disconnected when power is removed from the system and not automatically start back up when power is reapplied. In the past, I've used a PLC channel for this but it seems a bit overkill for such a simple function.
If you don't need the isolation, why use an SSR at all? A simple two-transistor latch would be much simpler.
If the circuit tends to power-up in the "on" state (and you don't want this), add a capacitor across SW2. If SW1 needs to be connected to a different voltage source, that works, too.
    \$\begingroup\$ For the heat transfer capability and convenient terminals of the hockey puck SSR package, I suppose. The drawing shows a 20A relay but I'd like to duplicate this on some of our larger (~70A) loads and having a readily available package/heatsink combination with well-defined thermal derating curves and built-in 8-32 screw terminals takes a lot of the guesswork out of the design. \$\endgroup\$
    – vir
    Oct 19, 2020 at 22:40
