Can you connect a Pyramid PS36KX 12-15V 32A DC Power Supply in parallel with a Tripp-lite PR 25 to get more amperage for my Ham Shack
Please follow this link and please let me know if this is possible using this method
https://www.keysight.com/main/editorial.jspx%3Fcc%3DUS%26lc%3Deng%26ckey%3D520808%26nid%3D-11143.0.00%26id%3D520808
    \$\begingroup\$ Most probably not. \$\endgroup\$
    – winny
    Commented Oct 20, 2020 at 21:55
    \$\begingroup\$ Hi, David. Standard practice is to include links to the datasheets for each item in your post. You can edit them in. What's your power-up sequence going to be? \$\endgroup\$
    – Transistor
    \$\begingroup\$ What do the manuals say about it? Power supplies can rarely be paralleled unless they specifically support it. \$\endgroup\$
    – Justme
    Commented Oct 20, 2020 at 22:03
  • \$\begingroup\$ Will see what I can find THANKS \$\endgroup\$ Commented Oct 20, 2020 at 22:56
Short answer: no. Power supplies designed for paralleling generally have a separate signal wire that goes between the (usually identical) units to coordinate output voltages and so forth. If there is no communication between the units, one of them will end up trying to force current into the other one due to voltage differences. Even if you have them adjusted to identical voltages at no load, they will droop at different rates as you draw more current and there you are.
Only two identical, fixed-voltage power supplies, which have the provision to do so, may be connected in parallel.
There is no way one could parallel two disparate supplies, one being rated 12-15V 32A and the other 13.8V 25A.
