-1
I was talking to a friend earlier about a class I'm thinking of taking. However, he warned me against taking it. The class is about chip design, microelectronics, and the physics behind them.
He said that the wires are all that's important. In fact, the total capacitance and resistance is dominated by the wires, so it doesn't matter how you change transistors. Is this true?
    \$\begingroup\$ This is a few lines that asks for mountains of effort in reply. You can quite easily research this on the internet. Please edit your question and explain in detail what you already know, show all that you have discovered for yourself on the subject. \$\endgroup\$ – TonyM Oct 21 at 5:58
    \$\begingroup\$ If that was true, the semiconductor industry would not spend billions on R&D to improve their fabrication processes in order to produce smaller and better transistors . \$\endgroup\$ – crasic Oct 21 at 5:58
  • 4
    \$\begingroup\$ Ignore your friend, take the class. Your friend is the kind of person who holds people back. Take advice from that friend and you'll end up flipping burgers to make living. \$\endgroup\$ – JRE Oct 21 at 6:09
6
Your friend doesn't know enough about the subject to be talking.
The transistors and other semiconductor devices on the chip carry out most of the work.
Passive components (resistors, capacitors, inductors) have a part to play in the proper function of most ICs, but without the semiconductor devices (transistors, diodes, etc.) on the chip the passive parts wouldn't do much.
There are highly paid engineers who spend their days designing transistors of various types and sizes and properties. They aren't doing it just for fun. Those transistors are important.
The chips in the ICs are so small and operate so fast that things you wouldn't normally consider can become problems.
At the frequencies some chips operate at internally, the metal conductors act like inductors. I mean, wire always acts like an inductor to some extent but you can ignore it because the inductance is so low. Not so in an IC where the rising edge of a signal may only be picosends wide, and nanohenries of inductance can smear the edge into uselessness.
The same goes for capacitance and resistance. There is always a bit of capacitance between two wires or resistance in a wire that you generally ignore. In an IC, those small effects can become very important.
Those effects are not the main function of the IC, though. Those effects are things that will prevent an IC from working if you don't account for them.
| improve this answer | |
