Assuming no load, how does continuously changing the distance between the plates of a capacitor (in a sinusoidal fashion for simplicity) affect the output voltage? Does electromagnetic induction come into play in this scenario?
I understand there will be an immediate change in the output voltage since $$ V = Q/C = \frac{Q}{\varepsilon}\frac{d}{A} $$ and clearly the permittivity constant will change sinusoidally itself.
But what about the fact that there is a time-changing electric field? We must have a perpendicular time-changing magnetic field as a result. Does this magnetic field affect the voltage across the plates?
If not, I believe that would mean the energy spent in changing the distance would be dissipated purely thermally.
(For clarity, this is not a question from an assignment or such.)
