What I've got
5x, 200Ah
LiFepo4 batteries in a 12V
, parallel bank. I'm looking at putting in a Sinister Diesel 320A
alternator to supply loads of juice to the battery bank. If this is even possible, without damaging the batteries and circuit, then I figure I don't really need to go the standard roof, solar panel array nonsense.
How I understand it
Low-powered alternators can get overloaded due to the very low internal resistance of lithium batteries drawing too much current from the alternator, causing it to overheat and burnout (if there's no dc-dc charger). My batteries have a 100A
max input charge and 35mΩ
resistance.
Questions
Q1 - do I have this right? - the input current will divide evenly among the batteries so each battery will "see" roughly 320A / 5 = 64A
Q2 - these batteries are equipped with an internal BMS. Does this control the battery charging such that it "shuts off" the battery from the circuit when it's fully charged? That's wishful thinking, probably, the BMS is more about internal cell balancing and not preventing harmful currents?
Q3 - overall, is what I want to do possible? I'm not going to hand-build any necessary parts, but I'm happy to purchase the proper hardware. However, as far as dc-dc chargers go, I wasn't really seeing anything above 60A
. I guess that'd be OK if I put a separate dc-dc charger on each battery? ... although that'd be one charger per battery which is annoying and costly.
Thanks for any guidance!
Update:
After considering everyones' feedback (thanks!) and ruminating on it for a while, I've decided just to go ahead and get a DC-DC charger. The output voltage of an alternator isn't quite high enough to bring LiFepo's up to a full charge. It took some hunting but I finally found a single maker that has a high-amperage charger that should do the trick: Sterling Alternator-to-battery Charger. So I'll put this between the beefy alternator and the battery bank. However, I'm still unclear on how to protect each, individual battery: there will be, say, 300A
feeding from the charger into the parallel bank. Each battery can't get more than 100A
applied to it. Is there some hardware I can install on each battery to limit the incoming current? Is there hardware that can fully open and shut off current when the full-charge voltage has been achieved?
