I'm working with an LTSpice schematic that I have formatted to print nicely to a PDF.
Does anyone know of a way to do do this printing using the command line instead of needing to open the schematic with LTSpice and print it manually?
This is very confusing to me: you say you prettyfied your schematic -- that could have been done only from the GUI -- yet you want to print it through the comand line?
Well, whatever the reason, you can't. The available command-line switches are in the help, under LTspice > Modes of Operation > Command Line Switches, and none deal with printing.
  • \$\begingroup\$ I use pandoc to product documents from combinations of different formats, like jupyter notebooks and word documents, into a single pdf. I current print my *.asc to a pdf and add it into my pandoc build script. Without being able to print from the command line I have to manage two documents, the asc and the pdf, and make sure they the pdf is kept up to date. It's minor. \$\endgroup\$ – progress every day Oct 22 '20 at 21:06
  • \$\begingroup\$ @progresseveryday That makes sense, but the result is the same, unfortunately. \$\endgroup\$ – a concerned citizen Oct 22 '20 at 21:17
