I made a 13.8V 10A linear power supply from a transformer took from a computer UPS whose battery was dead. Now the issue is when I touch the output of the regulator leads, or the power supply casing I felt a slight tingling sensation. I measured the voltages using a multimeter with one lead referenced to earth and got these readings,
negative rail and earth = 34 VAC
positive rail and earth = 34VAC
Casing and earth = 15VAC
some parts of the transformer and earth =15VAC.
This stray voltage was interfering with my other circuits I'm testing. Fortunately I was able to solve the problem by earthing the case and the output rails directly, but I still read a 1 to 2 Volts on my DMM. How is this effect happening? How do I get rid of this completely? Also I can read a 700mV on a 1N4148 RF detector probe in the close proximity to my PSU when ever I touch it or attach a 10cm wire to it. Is it just static from all the switching devices in my house or does it have to do anything with the PSU.
Here is the schematic,
    \$\begingroup\$ Sounds like inter-winding capacitance but really, you should post a schematic to be sure. \$\endgroup\$ – Andy aka Oct 23 at 7:59
  • \$\begingroup\$ I have added the schematic. Lets assume its inter-winding capacitance, it cant be avoided, so how does one minimize the effects? \$\endgroup\$ – ASWIN VENU Oct 23 at 8:33
    \$\begingroup\$ It's a bigger problem in switching power supplies because of the high frequencies involved but, it's also countered by the inter-capacitance being smaller. If "earth" is available and you can earth the DC output that is the easiest fix. If not, you will have to use non-electrolytic capacitors down to earth from the negative (and sometimes positive) DC output. \$\endgroup\$ – Andy aka Oct 23 at 8:39
  • \$\begingroup\$ I'll try both, how much should the non-electrolytics be in value? Also what do you think about the spooky readings on my rf pobe? \$\endgroup\$ – ASWIN VENU Oct 23 at 8:50
  • \$\begingroup\$ I can't comment on the RF probe but I'd start about 1 uF and see what happens. \$\endgroup\$ – Andy aka Oct 23 at 10:17
