The most common solution to provide positive and negative voltage to supply an OP-amp would be to use a voltage divider and another OP-amp. In this way the voltage "on the top" of the voltage divider would be the positive voltage, ground would be negative voltage and the voltage in between would be our virtual ground.
When working with audio-applications it is very important that these circuits do not create noise, so my question is: How do you design these to make sure they don't create noise? What OP-amp should you use?
