Fan Regulator
I came across this circuit in this link, but I am not able to understand how this RC circuit works.
  • Could someone explain it to me?
  • Should I consider this as a parallel RC circuits?
  • If the input is a 220V 50Hz sine wave, what will the waveform be?
  • How are the calculations of capacitors done?
The schematic is poorly drawn, if you would connect a fan to the red and black wires then the fan can never run as it receives no power.
Assuming this circuit is in series with the fan and that series combination is connected to AC mains voltage, then the relays either make:
  • a direct connection between the red and black wires, the fan will run at full speed.
or
  • connect the left circuit (R1, R2, C2)
and/ or
  • the right circuit (R3, R4, C2)
in series with the fan.
R2 and R4 are only 2.2 ohms so these don't do much (you can consider them a short). Probably R2 and R4 are added to limit the current when the capacitors are discharged and the mains voltage is applied.
R1 and R3 have a high value, they are there to discharge the capacitors C1 and C2 when everything is switched off.
C1 has a value of 2.2 uF and C2 is 3.3 uF. These capacitors are connected in series* with the fan. These capacitors have a certain impedance (similar to resistance) at the mains frequency. A larger capacitor (C2) will have a lower impedance. The impedance of these capacitors is in series with the fan and that makes the fan run slower.
All waveforms remain sinusoids as these RC circuits are linear, they do not switch.
  • \$\begingroup\$ Thank you for the answer. Could you explain a bit more about impedence and if it is similar to resistance, why cant we put a resistor instead of a capacitor? @Bimpelrekkie \$\endgroup\$ Oct 27, 2020 at 10:23
    \$\begingroup\$ If you would use a resistor then it would need to be a very large resistor (for high power) and that resistor would get very hot as well. There are many books, articles and videos that explain resistance and impedance so there is no need for me to explain it here. \$\endgroup\$ Oct 27, 2020 at 10:29
  • \$\begingroup\$ Ok, could anyone explain about impedence and how it makes fan slow? Any equations? I want to get my doubts cleared.. \$\endgroup\$ Oct 27, 2020 at 11:32
