I have an OPA4353 IC, that i want to figure out the pinout from the schematic. I know this is basic stuff, but since this is the first time I am doing this, and I will be designing a PCB from it, that takes time to arrive and money, I want to make sure I make this right.
This is the image from the datasheet:
And this is the actual IC:
I have labeled what I think is the pinout on the IC, with green numbers.
Is my assumption correct?
I came to this conclusion because the datasheet picture has a circle next to the pin named "1". I think the actual IC has that circle on the bottom left, therefore I arrived to the conclusion that the pin 1 must be there.
Is my assumption correct? What about pins 9-16? Are they in the correct order?
