I am trying to Reverse Engineering A PCB but I have problem to identify some PCB components(Highlighted components). I don't know whether these are transistors or FETs. As without knowing their actual model number i will not be able to identify their pin configurations.
1\$\begingroup\$ what is your question? \$\endgroup\$– jsotolaOct 28, 2020 at 7:51
2\$\begingroup\$ Those are SMD codes on the components, it isn't always possible to find what the actual component is. You can make a more educated guess by: 1) using a multimeter in diode mode to check for diode junctions in the transistors. 2) Examine the circuit around the transistor to see if it matches a commonly used circuit for a BJT or MOSFET. \$\endgroup\$– BimpelrekkieOct 28, 2020 at 8:08
