I am making a BLDC motor controller , so can you tell me the use of pullup resistor connected in the feedback of hall sensor.And is HO is equal to VB voltage when driver circuit operates ? Please explain the value of phase output voltage coming ( Explain any phase voltage).
2\$\begingroup\$ How can we read the datasheet to tell you the pull-up value if you don't tell us which part it is? \$\endgroup\$ – Justme Oct 28 '20 at 16:40
\$\begingroup\$ I only want to know the use of this pullup resistor \$\endgroup\$ – anmol kumar Oct 28 '20 at 16:51
6\$\begingroup\$ Maybe the outputs are open collector? Hard to say without a datasheet! \$\endgroup\$ – Aaron Oct 28 '20 at 17:05
Circuits with pullups generally pull down the voltage sharply to ground then let go, relying on the pullup resistor R to pull the voltage high. How quickly it can pull the voltage up is a function of R and any capacitance on the line.
If the sensor signal is changing so quickly that the pullup doesn’t have time to pull the voltage up between transitions then you have a problem. This limits the upper bound of R.
The lower bound of R is dictated by how much current the sensor driver can sink, which is a function of its output impedance.
Lacking any specifications of your sensor device, R=1K is a good place to start.
\$\begingroup\$ Lower limit of R is also dependent on the supply current available for it. \$\endgroup\$ – TonyM Oct 29 '20 at 5:56
