The fuse panel is breakered to a battery and is used to power other low amp equipment. The model is the 6 gang blue sea panel with blade type fuses.
Since the fuse panel is just a couple pieces of metal with fuse holders connecting them I didn't think it really mattered but it felt wrong routing the solar power "backwards" through the panel.
  • \$\begingroup\$ If you mean "OK" in the sense of building codes -- those vary by state or country, so check yours. If you mean "OK" in the sense of good design practice -- it's a bit strange, but it does provide a master fuse for the rest of the system. \$\endgroup\$ – TimWescott Oct 28 '20 at 19:54
  • \$\begingroup\$ I'm not worried about any electrical codes, just if it's as safe as what I typically do, which is to run the battery output through a separate shortstop, and into either the fuse panel positive input or straight to the battery depending on the location and necessary cable runs. This is all for a low 30 amp system. \$\endgroup\$ – GregoryNeal Oct 28 '20 at 20:21
  • \$\begingroup\$ "codes" are all about what has been discovered to be unsafe. is this a DC system? what voltage? part of a vehicle? \$\endgroup\$ – Jasen Oct 28 '20 at 21:52
  • \$\begingroup\$ DC 12 volt in a vehicle. I'm following recommended guidelines in terms of chassis grounds, wire gauge and correct breaker usage but I've found nothing to suggest this particular path for solar power is unsafe or even not recommended. \$\endgroup\$ – GregoryNeal Oct 28 '20 at 22:36
