First, I will present a method that uses Mathematica to solve this problem because you already have a very good answer by @Andyaka. When I was studying this stuff I used the method all the time (without using Mathematica of course).
Well, we are trying to analyze the following circuit:
When we use and apply KCL, we can write the following set of equations:
\begin{cases}
\text{I}_\text{k}=\text{I}_1+\text{I}_4\\
\text{I}_3=\text{I}_2+\text{I}_4\\
\text{I}_2=\text{I}_3+\text{I}_5\\
\text{I}_1=\text{I}_\text{k}+\text{I}_5
\end{cases}\tag1
When we use and apply Ohm's law, we can write the following set of equations:
\begin{cases}
\text{I}_1=\frac{\text{V}_1}{\text{R}_1}\\
\text{I}_2=\frac{\text{V}_\text{i}-\text{V}_1}{\text{R}_2}\\
\text{I}_3=\frac{\text{V}_1}{\text{R}_3}
\end{cases}\tag2
Now, we can set-up a Mathematica-code to solve for all the voltages and currents:
In[1]:=FullSimplify[
Solve[{Ik == I1 + I4, I3 == I2 + I4, I2 == I3 + I5, I1 == Ik + I5,
I1 == V1/R1, I2 == (Vi - V1)/R2, I3 == V1/R3}, {I1, I2, I3, I4, I5,
V1}]]
Out[1]={{I1 -> (R3 (Ik R2 + Vi))/(R2 R3 + R1 (R2 + R3)),
I2 -> (-Ik R1 R3 + (R1 + R3) Vi)/(R2 R3 + R1 (R2 + R3)),
I3 -> (R1 (Ik R2 + Vi))/(R2 R3 + R1 (R2 + R3)),
I4 -> Ik - (R3 (Ik R2 + Vi))/(R2 R3 + R1 (R2 + R3)),
I5 -> -Ik + (R3 (Ik R2 + Vi))/(R2 R3 + R1 (R2 + R3)),
V1 -> (R1 R3 (Ik R2 + Vi))/(R2 R3 + R1 (R2 + R3))}}
Now, we can find:
- \$\text{V}_\text{th}\$ we get by finding \$\text{V}_1\$ and letting \$\text{R}_3\to\infty\$:
$$\text{V}_\text{th}=\frac{\text{R}_1\left(\text{V}_\text{i}+\text{I}_\text{k}\text{R}_2\right)}{\text{R}_1+\text{R}_2}\tag3$$
- \$\text{I}_\text{th}\$ we get by finding \$\text{I}_3\$ and letting \$\text{R}_3\to0\$:
$$\text{I}_\text{th}=\text{I}_\text{k}+\frac{\text{V}_\text{i}}{\text{R}_2}\tag4$$
- \$\text{R}_\text{th}\$ we get by finding:
$$\text{R}_\text{th}=\frac{\text{V}_\text{th}}{\text{I}_\text{th}}=\frac{\text{R}_1\text{R}_2}{\text{R}_1+\text{R}_2}\tag5$$
Where I used the following Mathematica-codes:
In[3]:=FullSimplify[
Limit[(R1 R3 (Ik R2 + Vi))/(R2 R3 + R1 (R2 + R3)), R3 -> Infinity]]
Out[3]=(R1 (Ik R2 + Vi))/(R1 + R2)
In[4]:=FullSimplify[Limit[(R1 (Ik R2 + Vi))/(R2 R3 + R1 (R2 + R3)), R3 -> 0]]
Out[4]=Ik + Vi/R2
In[4]:=FullSimplify[%3/%4]
Out[4]=(R1 R2)/(R1 + R2)
Using your values we get:
- $$\text{V}_\text{th}=\frac{25}{2}=12.5\space\text{V}\tag6$$
- $$\text{I}_\text{th}=\frac{1}{4000}=0.0025\space\text{A}\tag7$$
- $$\text{R}_\text{th}=5000\space\Omega\tag8$$
