Is it bad coding practice to use Buffer Ports in VHDL?
I define an entity with an out port with o_done.
entity blahblah is
port (
...other signals...
o_done : out std_logic;
end entity blahblah;
The synthesizer does not like me reading an out port and wont synthesize it - even though it is legal VHDL 2008 code. I can't change my synthesizer.
I use o_done in 2 clocked processes:
process begin
wait until rising_edge(clk);
if (reset = '1') then
o_done <= '0';
else
if ( State1 ) then
o_done <= '1';
elsif ( o_done = '1' AND State0 ) then
o_done <= '1';
else
o_done <= '0';
end if;
end if;
end process;
process begin
count <= to_unsigned(0, 8);
else
if( stateS0 AND done = '1' ) then
elsif( stateS1 AND y_counter >= 2 AND p >= 0 ) then
count <= count + 1;
end if;
end if;
end process;
Again, o_done, since defined as out in the port declaration, is not synthesizable since the synthesis engine isn't fully VHDL 2008 compatible. I can't change the synthesizer.
So how do I work around o_done being an output port and wanting to read it ?
Can I make an intermediate signal - how do I do this typically ?
