I have to replace a USB-C connector. After desoldering I found a rather uncommon footprint. Has anyone seen this footprint before and knows where to find a new connector of this type?
Thank you!
  • \$\begingroup\$ It could be a footprint that is compatible with 2 parts. \$\endgroup\$
    – Wesley Lee
    Oct 30, 2020 at 20:28
  • \$\begingroup\$ It's rather close to a reference design of the USB Type-C Specification -- see figure 3-6 on page 51. \$\endgroup\$
    – Codo
    Oct 30, 2020 at 20:37
  • \$\begingroup\$ It looks like one pad is missing. \$\endgroup\$
    – Ron Beyer
    Oct 30, 2020 at 23:18
    \$\begingroup\$ This is a classic "combo" footptint, part through-hole, partly surface mount. \$\endgroup\$ Oct 31, 2020 at 0:50
welcome at EE.SE
An example for such a connector can be found here: https://www.digikey.com/en/products/detail/assmann-wsw-components/AUSB1-DFN-PTR3/5810164 The footprint is just a practical combination of smd and tht to use the board-space in a more efficient way.
I wish you luck with whatever you want to achieve with this board :)
  • \$\begingroup\$ Thank you so much, thats exactly the one I was looking for! \$\endgroup\$
    – zet0
    Oct 30, 2020 at 22:22
  • \$\begingroup\$ You can say "use the board in more efficient way", or better "to accomodate low-cost low-resolution cheaper PCB manufacturing". \$\endgroup\$ Oct 31, 2020 at 0:52
