How can I calculate the total resistance of resistors combination between points a and b ?
I have already designed the circuit and added a 1 A current source between a and b. For dependent current source I used component g (voltage dependent current source).
Electrical circuit
Solving node equations I was able to find Rab using Ohm's law . According to my calculations V1 = 1.8282... V and V2 = 5.4545... V .
Rab = Vab / 1 = Vx
III_LTspice
My question is how can I find voltage Vab = Vx ?
  • \$\begingroup\$ For your circuit with a 1A current source, the Vx voltage is equal to 5.4545..V \$\endgroup\$
    – G36
    Oct 31 '20 at 21:45
    \$\begingroup\$ Your inputs for the VCCS are reversed. \$\endgroup\$ Oct 31 '20 at 22:13
  • \$\begingroup\$ @aconcernedcitizen Thank you very much, that solved the problem . \$\endgroup\$
    – estamos
    Nov 1 '20 at 9:01
Ignoring the problem pointed out in comments where you didn't correctly capture the schematic,
Your b node is connected to ground so its voltage (as reported by SPICE) is always 0.
Therefore what you call \$V_{ab}\$ is what SPICE calls V(a), which is reported in the screen image you provided.
