How to find the Thevenin equivalent circuit as seen from terminal a-b.
I found out the value of Zth with ease but I'm not able to find the value of Vth.
I tried using both nodal and mesh analysis and I got an answer of 57.8378 - 2.972j V for Vth, but it is wrong.
KVL equation (4-2j)I1 + (8+4j)I2 + Vth=0 (Considering current flowing in lower loop as I1 and upper loop as I2).
KCL at node 2: -V0/(8+4j) = 5 + 0.2V0.
I don't know how to get the correct answer.
  • \$\begingroup\$ What is the correct answer, that you know? \$\endgroup\$ Nov 1, 2020 at 17:01
  • \$\begingroup\$ @Jan Yes. The one you posted as the answer is the correct one. 80/37 + (260/37)j \$\endgroup\$ Nov 1, 2020 at 17:05
First, I will present a method that uses Mathematica to solve this problem. When I was studying this stuff I used the method all the time (without using Mathematica of course).
Well, we are trying to analyze the following circuit:
When we use and apply KCL, we can write the following set of equations:
$$ \begin{cases} 0=\text{I}_\text{k}+\text{I}_1+\text{I}_4\\ \\ \text{I}_2=\text{I}_\text{k}+\text{n}\cdot\left(\text{V}_2-\text{V}_3\right)\\ \\ \text{I}_3=\text{I}_2+\text{I}_4\\ \\ \text{n}\cdot\left(\text{V}_2-\text{V}_3\right)=\text{I}_1+\text{I}_3 \end{cases}\tag1 $$
When we use and apply Ohm's law, we can write the following set of equations:
$$ \begin{cases} \text{I}_1=\frac{\text{V}_2-\text{V}_1}{\text{R}_1}\\ \\ \text{I}_1=\frac{\text{V}_1}{\text{R}_2}\\ \\ \text{I}_3=\frac{\text{V}_3}{\text{R}_3}\\ \\ \text{I}_4=\frac{\text{V}_2-\text{V}_4}{\text{R}_4}\\ \\ \text{I}_4=\frac{\text{V}_4-\text{V}_3}{\text{R}_5} \end{cases}\tag2 $$
Now, we can set-up a Mathematica-code to solve for all the voltages and currents:
In[1]:=FullSimplify[
 Solve[{0 == Ik + I1 + I4, I2 == Ik + n*(V2 - V3), I3 == I2 + I4,
   n*(V2 - V3) == I1 + I3, I1 == (V2 - V1)/R1, I1 == V1/R2,
   I3 == V3/R3, I4 == (V2 - V4)/R4, I4 == (V4 - V3)/R5}, {I1, I2, I3,
   I4, V1, V2, V3, V4}]]
Out[1]={{I1 -> -((Ik (1 + n R3) (R4 + R5))/(
    R1 + R2 + R3 + R4 + R5 + n R3 (R4 + R5))),
  I2 -> (Ik (R1 + R2 + R3 + R4 + R5 - n R1 (R4 + R5) -
      n R2 (R4 + R5)))/(R1 + R2 + R3 + R4 + R5 + n R3 (R4 + R5)),
  I3 -> -((Ik (-1 + n (R1 + R2)) (R4 + R5))/(
  I4 -> -((Ik (R1 + R2 + R3))/(
  V1 -> -((Ik R2 (1 + n R3) (R4 + R5))/(
  V2 -> -((Ik (R1 + R2) (1 + n R3) (R4 + R5))/(
  V3 -> -((Ik (-1 + n (R1 + R2)) R3 (R4 + R5))/(
  V4 -> Ik (R4 - ((1 + n R3) (R1 + R2 + R4) (R4 + R5))/(
      R1 + R2 + R3 + R4 + R5 + n R3 (R4 + R5)))}}
Now, we can find:
  • \$\text{V}_\text{th}\$ we get by finding \$\text{V}_3\$ and letting \$\text{R}_3\to\infty\$: $$\text{V}_\text{th}=\frac{\text{I}_\text{k}\left(\text{R}_4+\text{R}_5\right)\left(1-\text{n}\left(\text{R}_1+\text{R}_2\right)\right)}{\text{n}\left(\text{R}_4+\text{R}_5\right)+1}\tag3$$
  • \$\text{I}_\text{th}\$ we get by finding \$\text{I}_3\$ and letting \$\text{R}_3\to0\$: $$\text{I}_\text{th}=\frac{\text{I}_\text{k}\left(\text{R}_4+\text{R}_5\right)\left(1-\text{n}\left(\text{R}_1+\text{R}_2\right)\right)}{\text{R}_1+\text{R}_2+\text{R}_4+\text{R}_5}\tag4$$
  • \$\text{R}_\text{th}\$ we get by finding: $$\text{R}_\text{th}=\frac{\text{V}_\text{th}}{\text{I}_\text{th}}=\frac{\text{R}_1+\text{R}_2+\text{R}_4+\text{R}_5}{\text{n}\left(\text{R}_4+\text{R}_5\right)+1}\tag5$$
Where I used the following Mathematica-codes:
In[2]:=FullSimplify[
 Limit[-((Ik (-1 + n (R1 + R2)) R3 (R4 + R5))/(
   R1 + R2 + R3 + R4 + R5 + n R3 (R4 + R5))), R3 -> Infinity]]
Out[2]=-((Ik (-1 + n (R1 + R2)) (R4 + R5))/(1 + n (R4 + R5)))
In[3]:=FullSimplify[
 Limit[-((Ik (-1 + n (R1 + R2)) (R4 + R5))/(
   R1 + R2 + R3 + R4 + R5 + n R3 (R4 + R5))), R3 -> 0]]
Out[3]=-((Ik (-1 + n (R1 + R2)) (R4 + R5))/(R1 + R2 + R4 + R5))
In[4]:=FullSimplify[%2/%3]
Out[4]=(R1 + R2 + R4 + R5)/(1 + n (R4 + R5))
Now, using your values we get:
  • $$\underline{\text{V}}_{\space\text{th}}=\frac{80}{37}+\frac{260}{37}\cdot\text{j}\tag6$$
  • $$\underline{\text{I}}_{\space\text{th}}=\frac{10}{37}+\frac{60}{37}\cdot\text{j}\tag7$$
  • $$\underline{\text{Z}}_{\space\text{th}}=\frac{164}{37}-\frac{22}{37}\cdot\text{j}\tag8$$
Where \$\underline{x}\$ implies that the value is a complex number, so \$\underline{x}\in\mathbb{C}\$.
  • \$\begingroup\$ Thanks for the answer. But I'm not really used to solving circuits using Mathematica. If possible can you please provide an answer using traditional methods? \$\endgroup\$ Nov 1, 2020 at 16:56
  • \$\begingroup\$ @RakshithKrish you're welcome, it is possible to solve this without Mathematica. The only thing I did was using Mathematica to solve the equations, but in the time I was studying this stuff I did this by hand instead of using a software. \$\endgroup\$ Nov 1, 2020 at 16:57
    \$\begingroup\$ Ok. I actually got the answer just using KCL at node at 2 and 3. By solving both the KCL equations I found out V3 which is the answer. \$\endgroup\$ Nov 1, 2020 at 17:37
