The SN74LVC1G17 was used on a DIO circuit as a buffer on a FPGA. Is it used to have a higher current on the output ? Here is the datasheet https://www.ti.com/lit/ds/symlink/sn74lvc1g17.pdf?ts=1604252447419
  • \$\begingroup\$ Please edit your question and detail your situation and what you are working on - in considerable detail. \$\endgroup\$ – TonyM Nov 2 '20 at 15:54
  • \$\begingroup\$ Which way it was buffering? Into FPGA, or from FPGA? \$\endgroup\$ – Justme Nov 2 '20 at 16:15
  • \$\begingroup\$ it's typically very rare for general IO to be directly connected to an fpga pin if for no other reason than the io voltage on fpga or at least a modern one is fairly low... Also you have to start considering things like ESD etc. \$\endgroup\$ – MadHatter Nov 2 '20 at 16:51
  • \$\begingroup\$ @Justme the circuit is doing both. \$\endgroup\$ – Amen0 Nov 2 '20 at 17:02
  • \$\begingroup\$ @MadHatter Thank you. \$\endgroup\$ – Amen0 Nov 2 '20 at 17:02
-1
Yes, the main purpose is to have an output signal wich is more robust than the input signal, expecially when the next circuit is edge-sensitive (i.e. you need very steep edges).
    \$\begingroup\$ Thought I would not vote this answer up, I don't understand why it has been voted down. \$\endgroup\$ – Fredled Nov 2 '20 at 21:10
