I am looking for a simple way for getting the RMS power output of an amplifier channel set to some arbitrary gain. I want this in order to find the maximum level I can safely set the amplifier at for a speaker with a given continuous power rating.
Edit to add more context: I often don't get to choose the gear I work with, so there are often mismatches between amplifier power and speaker maximum power handling. I want to find the maximum I can set the amplifier gain at without blowing speakers.
The volume control will be at signal source. I want to know that even if the signal gain is set to 0dB, the amplifier's volume will ensure the speakers will not be blown. If it helps, think of it as a theoretical exercise.
I came across this youtube video that suggests that by measuring the resistance of the disconnected speaker, and AC voltage across speaker terminals (while outputting to speaker), you can calculate RMS power from the equation \$𝑃=\frac{𝑉^2}{𝑅}\$, but all the other articles and videos I found suggested using a clamp meter to measure current, plus a regular multimeter to measure V, and calculate P from: \$P=IV\$
My question: Are both methods equally reliable? Are there practical considerations besides the fact that method 1 requires disconnecting the speaker and method 2 requires an extra measurement device?
