I am copying a schematic in EAGLE to make a battery protection board (https://www.homemade-circuits.com/battery-over-discharge-protection/)
I am very unexperienced in writing relays in schematics, and am unable to know exactly how to wire up the relay in the schematic editor, because the relay symbol is very different than what I am accustomed to. Not to mention, the names of the pins is the only thing I have to work with, since that's the only help they give. (The relay they show in there schematics has no schematic resemblance whatsoever):
Below is a schematic of a typical relay, Displaying the pin names:
schematic 1
(Courtesy of circuit-diagramz.com)
Below is another Schematic of the same type of relay from Autodesk EAGLE. I wrote the same names for the pinouts in green, but I'm not 100% sure if I'm correct. For starters the switch is flipped upside down, and for another, instead of N/O and N/C. it just says 'S' and 'O':
schematic 2
    \$\begingroup\$ It looks fine what you have done. \$\endgroup\$ – Andy aka Nov 3 '20 at 18:59
  • \$\begingroup\$ So I named everything right in the eagle schematic? @Andyaka \$\endgroup\$ – X Builder Nov 3 '20 at 19:19
    \$\begingroup\$ @XBuilder Yes... \$\endgroup\$ – Unimportant Nov 3 '20 at 19:23
  • \$\begingroup\$ i think that you need to disassemble a relay and examine how it operates ... doing that would clear up your misunderstanding \$\endgroup\$ – jsotola Nov 3 '20 at 19:49
