This is my first post in this stack group, so please forgive me for any shortcomings of my question.
I'm designing a circuit for a high side switch of around 60V DC (battery). Attached is a sketch of the circuit I have so far. VBat is around 60V, the switch here is a voltage controlled switch, switching for 2 seconds - in real life it will be a simple "hand controlled" momentary switch. R7 represents the load (which will be a voltage regulator in the end).
When simulated the circuit seems to work, but I don't know if this approach is reasonable.
My three main questions are:
  • The voltage divider R1 / R2 brings the 60V down to 10V, because most momentary switches seem to be built for 12V. That's why i choose R1 / R2 to be so high, to get the constant leakage current down as much as possible. Do I have to fear any antenna, or other undesired effects with such high resistances?
  • Is there a better approach, without leakage current, to use 12V switches?
  • Is there maybe a better approach in general?
Just to be on the same page, here is a short description of what the circuit should do: As long as somebody presses (and holds) the momentary switch (voltage regulated in the schematic just for simulation) the load, represented by R7, should be switched to 60V on the high side. Later the load will be a voltage regulator that ouputs 5V to power a micro controller and some leds. That's why I was thinking about a high side switch, to have the same ground for all components.
    \$\begingroup\$ Connect SW4 over R2 and the base to the middle of R1 & R2. \$\endgroup\$ Nov 4, 2020 at 14:33
  • \$\begingroup\$ i.e. don't leave inputs floating subject to stray interference from very high impedance and low current noise. \$\endgroup\$ Nov 4, 2020 at 14:35
  • \$\begingroup\$ you mean short the base of q1 to ground with a resistor? \$\endgroup\$
    – wschopohl
    Nov 4, 2020 at 14:36
  • \$\begingroup\$ No. Keep bias on Vbe to gnd at all times with pullup, then shunt base to ground .. You can always use BC846BLT3G NPN 65V on low side then mechanical switch Vbe//Load*20 to pullup x5 Rbe for 60V \$\endgroup\$ Nov 4, 2020 at 14:44
    \$\begingroup\$ If the load is only a separate 5V regulator, you might try looking for a regulator that has an output enable pin. It's a reasonably common feature, and that would (probably) be usable with a low-voltage switch. \$\endgroup\$
    – W5VO
    Nov 4, 2020 at 15:28
You need to back up your thinking about five steps. It should not be
  • I need to cut off the input to a regulator, so
  • I need a high-side switch, so
  • I need to convert from a low-side switch
Instead, it should be
  • I need to disable a regulator, so
  • I need a regulator with an enable line.
The simplest case is something like a ZXTR1005K4 with 100Vdc in max, 5Vdc out fixed, and your pushbutton going to the enable line. This doesn't take into account that - if I were to make a highly dubious guess that your regulator input current is 60V/400R = 150mA, this would exceed the current rating of this device and you'd have to shop around a little more.
The even simpler thing to do is revise your idea that it's hard to get a 60V-capable pushbutton, and simply put it in the input path of a fixed regulator with no enable. There are many off-mom switches that satisfy your criteria.
  • \$\begingroup\$ "Should" implies an unnecessary authoritative directive. The designer may choose either a 1) high side or a 2) low side switch primary switch or an 3) enable line or a 4) secondary switch, depending on other considerations not given, such as Off current limit, On current limit, cost but a floating input is the only critical fault , susceptible to stray noise and false trigger when off. \$\endgroup\$ Nov 5, 2020 at 8:21
-1
Better way
Down side is R102 uses 700 mW and must be rated for >=1W
Keep a logical loop as physically small area as possible ( twisted pair) to minimize a loop antenna effects. Add RF Cap to Vbe for AM or arc noise interference suppression >100kHz >> 20 dB eg 1 kHz
  • \$\begingroup\$ Sorry for my stupid questions, but: I see no switch in the latter examples and your first example seems to do the opposite from what I want.. In your example the mosfet is always on and off when the switch is closed, right? \$\endgroup\$
    – wschopohl
    Nov 4, 2020 at 15:05
  • \$\begingroup\$ The square wave signal is your switch . Did you want to show that as your finger? \$\endgroup\$ Nov 4, 2020 at 15:07
  • \$\begingroup\$ Haha, no. But in reality there is no square wave signal. Only the 60V and a switch. And the switch is just rated for 12V. And am I correct about your first solution? \$\endgroup\$
    – wschopohl
    Nov 4, 2020 at 15:15
    \$\begingroup\$ now you tell me .. Put ALL SPECS for DESIGN in question before you design anything \$\endgroup\$ Nov 4, 2020 at 15:20
    \$\begingroup\$ i love your finger drawing ;) ! just one question about 1st sketch: isn't the switch at 60V when it's open? Is that in conflict with the spec of the switch being 12 V? \$\endgroup\$
    – wschopohl
    Nov 4, 2020 at 15:24
