I'm working through this handout I3.PDF to help me understand feedback in common emitter amplifiers. (The author does not reveal his/her name in the PDF and so I can't ask them directly.) They show a common emitter circuit at the top and a small-signal model just below it. What expression defines the resistance \$R_B\$ in the model?
I'm imagining two possibilities. First, it might be be some combination of \$R_1||R_2\$. This doesn't seem correct. In the upper schematic \$R_1\$ appears between base and ground whereas \$R_2\$ appears between \$V_{CC}\$ and the base. But in the small-signal equivalent, \$R_B\$ appears only between base and ground. The second possibility is that it is simply \$R_1\$ alone. With us only considering small-signal (AC) voltages, \$V_{CC}\$ would appear as ground and so we ignore it and the resistor directly connected to it? Both of my guesses seem flawed.
