I am trying to read data from the ADC and display it on a HD44870 compatible LCD with an ATmega32. As the data from the ADC is a 10-bit unsigned integer, the LCD expects a string, some conversion is necessary. Below is the function i wrote to accomplish this conversion.
char *int_to_str(uint16_t num, uint8_t len){
    uint8_t i;
    char *str;
    str[len]='\0';
    for(i=(len-1); i>=0; i--){
        str[i] = '0' + num % 10;
        num/=10;
    return str;
However, the above function does not work. I just get a blank display where the numbers should be displayed. I am currently using itoa() and it works. However, i would prefer to write my own since size of the resulting executable is critical. Thank you.
  • \$\begingroup\$ Check up on sprintf(). You are confusing integer and string manipulation. \$\endgroup\$
    – jippie
    Jan 6, 2013 at 17:01
  • \$\begingroup\$ sprintf probably uses itoa internally,and is likely to be larger. \$\endgroup\$ Jan 6, 2013 at 18:16
  • \$\begingroup\$ Why do you think writing your own implementation of itoa() will be smaller? \$\endgroup\$
    – Phil Frost
    Jan 7, 2013 at 3:39
There is no reason why sprintf wouldn't work. This basically prints a string to a buffer instead of standard output.
As an example
char string[256];
int value = 5;
memset(string,0,sizeof(string[0])*256); // Clear all to 0 so string properly represented
sprintf(string,"Value: %d",value);
string will now contain the string "Value: 5"
Your way of handling strings is incorrect. You've just made a stack variable pointer to a string that is not initialized and does not point to a string with a valid length.
Declare str as str[len] and try that way.
    \$\begingroup\$ Your first paragraph is correct, and probably adresses correctly the original problem. But "Declare str as str[len] and try that way" is a big no-go when you return a pointer to that (local!) variable later, as the OP intends to do, see return str;. \$\endgroup\$
    – JimmyB
    Sep 10, 2016 at 20:16
