I'm going to convert my DeWalt charger from 110V to 240V as I got sick of lugging a step converter around.
I have found two guides which use the exact model of charger I have but they have partly different solution. I would like to know more of what could be the reason that they did what they did.
It is clear that the transformer that powers the charging circuit can handle 240V. Both of the guides replaced the 200V 220uF which I totally understand - that capacitor would pop under 240 VAC and should be replaced with a value above the peak 400V + should be fine.
Now the similarities end, the first guide changed the capacitor and added 2 0.33Ohm 5W resistors.
The second guide did not speak in english so I did not understand what he was saying but basically I think he add a varistor on the main input and instead of using a resistor I'm not sure what that black thing is (ceramic capacitor?) but why would he add a capacitor? If you closely look on either of the videos you might notice that that slot is labeled "R" so I assume a resistor is supposed to be placed there (instead of a jumper.)
Can someone help explain to me what could they possibly be doing? Sadly I don't currently have my charger so I can't take more detailed pictures of the circuit. But maybe someone may have an idea based on past experience.
