I have a circuit like this: enter image description here
I am using a LT1719 for the Schmitt trigger. The Schmitt input signal is intended to be a 6 kHz waveform of 0.6 V pk-pk amplitude.
When I test the Schmitt with an individual signal using a function generator, it is working like this: enter image description here.
It means that the Schmitt working individually. However, when I connect the passive LPF output to the Schmitt trigger, there is no Schmitt output even though the LPF output is has a DC value of almost 0.7 Volt. (While is was totally zero crossing before connecting to Schmitt).
I have checked using a buffer between LPF and Schmitt to reduce the loading effect but there was no output again.
Can you please help me. Thanks.
  • \$\begingroup\$ A very warm welcome to the site. It looks like English might not be your first language so I've tried to clarify your post as best I can. It still needs some further improvements from you, though, as I don't want to guess what you meant too much. Please edit your question to make those improvements. Thanks and, again, welcome. \$\endgroup\$
    – TonyM
    Commented Nov 10, 2020 at 21:18
Could be any combination of several things:
You do not re-establish a stable DC reference voltage for the signal after the lowpass filter. The 1.2 K resistor has a capacitor on each end. As a start, add a 1 M resistor to GND in parallel with the 1.2 nF LPF capacitor.
The LT1719 is not a normal comparator, and has its own internal hysteresis. Why are you adding additional hysteresis around it?
Separate from that, with it running on +/-5 V, the two externally set trip points are +/-326 mV. (Maybe - I have not worked through the output stage configuration.) That is 0.652 V peak to peak, which is greater than the input signal.
As previously mentioned, the problem is the DC level after the DC coupling. There is no DC path to ground on either end of the 1.2K resistor...except the LT1719 inverting input. Taking a look at the LT1719 datasheet, specifically the I.sub.B "Input Bias Current" specification, 2.5uA of current will typically flow out of that terminal (positive values flow into a device) into your Passive LPF, with limits of -6uA to 0uA.
There is also a graph labeled "Input Current vs Differential Input Voltage" that shows it is a little more complicated than the one number I.sub.B captures (which is the value at 0V differential input). So this current will not, and could not charge the DC level to infinity, but the mean value of that curve is negative so the DC voltage at that input will have to rise considerably to reach equilibrium.
With the output stage configured to run between +3V and ground as you have shown, the trip points should be ~0 and ~200mV using the positive feedback resistor values chosen. It would not surprise me at all if the LT1719 input bias current were charging the LPF DC level to the 700mV reading you mention, which is keeping it from tripping even with a 600mVp-p square wave riding on that. [700mVdc - 600mV/2 = 400mVdc(min) > 200mV trip point.]
You mentioned that using a function generator to drive the Schmidt trigger proves that it is functional. I assume this is the case because the function generator output provides 50 Ohm termination to ground. To prove that the DC level is the problem, you should see what happens when you connect the function generator output in place of the Envelope Detector circuit, leaving your DC coupling and Passive LPF intact.
To fix this, either provide a DC path to ground, or remove the DC coupling. The choice depends on why you wanted the DC coupling in the first place, and how you want the overall circuit to behave. A 1 Meg-Ohm resistor that bleeds a few micro-Amps to ground will cause a DC level of a few mV, but it doesn't seem like precision to that level would be a concern in a circuit like this.
