Please, help identify this MOSFET and equivalent. One circuit has them marked as "P40 1340" and the other has "S36 1410".
It's part of a circuit of 2 MOSFETs that act as power switches controlled by an MCU pin. It operates down to 2 Volts and handles up to 3A.
I am hoping to find the same or with equivalent rating. I found a MOSFET numbered as "TC1410", but it does not seem to have the same package even offered. And I could not find any MOSFETs with a marking of "1340".
EDIT: If cannot identify them, I think this could be a substitute: IRF7317TRPBF‎, Infineon Technologies, MOSFET N/P-CH 20V 8-SOIC
https://www.infineon.com/dgdl/irf7317pbf.pdf?fileId=5546d462533600a4015355f5b8de1b3d
DMC2038LVTQ-7‎, Mosfet Array N and P-Channel Complementary 20V 3.7A
https://www.diodes.com/assets/Datasheets/products_inactive_data/DMC2038LVT.pdf
photo of MOSFET marked P40 1340
photo of MOSFETs marked S36 1410
schematic diagram
Diodes Incorporated DMP2008UFG has a matching package and "marking information" in datasheet says S36. DMP4025SFG from the same manufacturer has marking P40.
The other numbers are production year/week.
  • \$\begingroup\$ Wow.,.thank you! I am good at finding things but this one eluded me! \$\endgroup\$
    – TommyS
    Nov 11, 2020 at 20:43
