I have a small problem with my LTspice simulation...
When you have a system that contains multiple capacitors, inductors and resistors, how do you know, when you measure its equivalent impedance Z using an .ac simulation in LTspice (for example), what components resonate (which L with which C). To give you guys a context, I have [this][2] schematic below, that has the same resonance frequency (but not the same amplitude though) to same schematic but with different values of the parameters: R12, C12, R13, C13, Rm1, Cm1, Rm2, Cm2, Rm3, Cm3. Does this seem reasonable to you guys? or do you think I am doing something wrong somewhere?
