I was digging through my things and found this component (48-27SD50020222
) but am not sure what it is.
I've tried searching for variations of the number 48-27SD
, 48-27SD500
, 27SD500
, etc. but no luck.
Would any of you know?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI was digging through my things and found this component (48-27SD50020222
, 48-27SD500
, 27SD500
, etc. but no luck.
The comments are correct. That is an IR receiver. It can be used for decoding IR signals from IR transmitters, such as a typical TV remote. And if I'm correct, if it is paired with an IR transmitter, it can be used for short-range distance detection.
You can buy them from any standard online electronics store:
sparkfun.com
digikey.com
adafruit.com
