I am trying to simulate a mosquito repellent in Proteus v7.7. It uses an NE555 in astable mode.
My problem is that I cannot hear the buzzer buzzing.
I checked my circuit and everything seems correct to me. Could you please tell me what is wrong?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI am trying to simulate a mosquito repellent in Proteus v7.7. It uses an NE555 in astable mode.
I have built this circuit in my version of Proteus, and your output of the 555 will only reach 5V output in this circuit. You can double check this by setting your scope to DC and looking at the output. This is likely due to the load the buzzer puts on the output.
Your buzzer is a 12V buzzer. Even if your output was equal to your input voltage of 9V, that's still not enough to drive the buzzer. When you are in the buzzer properties menu, change the operating voltage value to 5V and it'll work.
Alternatively, you could toggle an NMOSFET to switch the buzzer, and attach the gate to the output of the 555, but you need to ensure either a 12V supply, or change the buzzer operating voltage.
Both of these methods I have built myself and they work.
