I am trying to draw a footprint in Eagle (datasheet PDF).
This isn't the first time I had to draw a part without enough dimensions, but I'm wondering if there is an easier or more precise method. Previously, I assumed the drawing was to scale and used Microsoft Publisher:
  • File > Options > Advanced. Then under Display, next to Show measurement in units of, select Centimeters.
  • Paste the drawing into Publisher, draw a line, left click, Format AutoShape, Size and set a large border dimension (e.g., 3.8 cm).
This somewhat works for basic linear dimensions. For uniquely shaped pads (not in this example) I imported a bitmap from Paint. Is there a less complicated way if the pad diagram is not available?
Also, any idea what the two different connectors are for that part? The larger connector appears to be a MOLEX 43650-0413. The white/yellow connector I do not know. It has four SMT pads (similar to a squirrel track with wide front legs).
If it "actually matters", contact the manufacturer and ask for mechanical drawings.
If it doesn't matter that much, do what you're doing (which is, roughly, what I would do for hobbyist applications), or as an alternative, import the footprint as an image directly into Eagle. I haven't tried this myself but there are many tutorials.
