I have created an inverter using cmos logic (see image)
Inverter circuit
However, when I simulate the circuit model, even without a load I get an output voltage that remains fairly high rather than going low (see image).
Inverter waveform
Any insight that anyone can provide with regards to my issue will be very much appreciated.
Your PFET is "upside down" (source and drain erroneously interchanged) and you are probably getting a path through the body diode even when it is off. Apparently in the device models you are using, the diode "defeats" the NFET.
