I have an application where I have the following components installed.
277 Vac to 48 Vdc Constant Voltage Driver (MeanWell) -> 48 Vdc CV PWM dimming interface controlled by 0-10 V -> constant current strip (44-48 V and can be run at 40, 50 or 60 mA per segment)
It appears to work correctly, but are there any long term issues with running a constant current strip with a constant voltage supply, as long as the current draw (maximum current available by driver is less than the combined segment maximums) and voltage are within range for the strip?
Is there an issue with the PWM function on the constant current strip?
