If it possible to amplify the RF emitted from my key fob to dramatically increase it's range when attempting to remote start my car? My wife is a nurse and leaves the hospital late at night. She'd like to remote start her car (especially in the winter) to minimize the amount of time she spends in the parking lot.
Any ideas?
Even if it's something she has to carry in her purse that's OK. Other people have RKE systems that operate over a longer distance and they can start their car OK, but my wife's is not powerful enough. Tried changing the battery, but that didn't help.
closed as off-topic by Joe Hass, Dave Tweed, PeterJ, Daniel Grillo, Chetan Bhargava Dec 24 '13 at 0:28
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Joe Hass, PeterJ, Daniel Grillo, Chetan Bhargava
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Info on car model or keyfob fcc id would help. If it's a keyless start, those have a range of ones of feet and are similar to rfid. If it's a remote starter keyfob, it might just need a better antenna, but we need something to base it off of. \$\endgroup\$ – Passerby Jan 8 '13 at 0:33
  • \$\begingroup\$ Like Passerby said, we need frequency band information etc. in order to answer this one properly. \$\endgroup\$ – Mels Jul 26 '13 at 14:49
  • \$\begingroup\$ Possible yes. Easy no. The first approach is install an big antenna on receiver or transmitter (or both). \$\endgroup\$ – user19978 Aug 25 '13 at 20:09
Have her put the tip of the key in her open mouth, aimed at the car, with the key's metal touching a front tooth. Absolutely not kidding. Can't pretend to understand the theory, but maybe a waves guru can explain. I think its effective line-of-sight.
Have her try pointing the key on the key fob directly towards the ca while trying to ensure a clear line of sight between her key fob and the car. A key fob is a small radio transmitter and these might help get the signal through.
  • \$\begingroup\$ That's not what the OP asked for. \$\endgroup\$ – Mels Jul 26 '13 at 14:46
