I am looking to visualize a binary sequence for a tutorial.
For example, I have an oscillating CLK signal. Also there is serial data being inputted on INPUT pin. I want a graphical visualization of this timeinline, exactly like you would see on a logic analyzer.
i.e. to take an image from a previous post of mine: image
It doesnt need to be as fancy showing ACK or anything like that. There must be a solution other than writing VHDL code and simulating or actually creating the circuit and capturing the output.
  • \$\begingroup\$ In case you are familiar with LaTeX, the tikz package is a nice thing. But I don't think you are. Are you? \$\endgroup\$
    – user17592
    Jan 7 '13 at 20:43
  • \$\begingroup\$ I have not used LaTeX before.. Will look into it. \$\endgroup\$
    – Michael
    Jan 7 '13 at 20:43
  • \$\begingroup\$ If you're not familiar with it, use software designed for it! Learning LaTeX is quite hard. The nice thing would be you can generate your images within the document. But I wouldn't recommend learning LaTeX just for this ;-) \$\endgroup\$
    – user17592
    Jan 7 '13 at 20:45
  • \$\begingroup\$ I have seen many logic analyzers that boast great analyzers for things like this. \$\endgroup\$
    – Kortuk
    Jan 7 '13 at 21:08
    \$\begingroup\$ I usually do all my (more or less realtime) plotting with gnuplot. gnuplot.info And this for logic analyzer stuff lxtreme.nl/ols \$\endgroup\$
    – jippie
    Jan 7 '13 at 21:35
HERE is a link to a decent timing diagram generator. It is free for now. And is under active development. Java based so portable.
THere is also Timing diagrammer pro from Syncad. It is a paid app. but works well.
    \$\begingroup\$ Don't accept so fast! there is a distinct possibility that a better solution will pop up! \$\endgroup\$ Jan 7 '13 at 20:49
  • \$\begingroup\$ Hah. I'll unaccept yours if a better one comes up. I am using it now and I think it is fine... \$\endgroup\$
    – Michael
    Jan 7 '13 at 20:55
  • \$\begingroup\$ @mike - the critical thing is fewer people answer questions with an accepted answer. As such, you're much less likely to get a second answer if you've accepted the first all ready. \$\endgroup\$ Jan 7 '13 at 21:02
  • \$\begingroup\$ +1 vote for unaccepting it for the time being. I'd like to see what everyone is using. \$\endgroup\$
    – user17592
    Jan 7 '13 at 21:05
