Below I have this simulation.
The diodes represent the clamping diodes placed inside the microcontroller GPIO pins.
Case 1 - Given directly using the voltage source.
Case 2 - Given the same voltage through a resistor divider.
In the above image, both the circuits are providing 12V at the GPIO pin. But first one is given through the voltage source. Second is through a resistor divider network. But effectively, same voltage is given and provide at the GPIO pin. But we are getting different results.
I understand that in the first case, since the Voltage source output is very low impedance, it is showing 12V. But I am confused on this behaviour and unable to arrive at a conclusion on how the 2 cases are different. Please help to provide an answer in simple terms for my clarity.
  • \$\begingroup\$ In your first circuit, the diode will burn immediately. But in the second case, the diode current is now equal to around (12V - 5V)/500 = 14mA thus, it will survive and this is why you have 5.7V at the input. \$\endgroup\$
    – G36
    Nov 17, 2020 at 15:09
  • \$\begingroup\$ It is not very low impedance, it is an ideal voltage source, so it has no impedance. Any node you connect it to will be forced to have that voltage. \$\endgroup\$
    – Arsenal
    Nov 17, 2020 at 15:10
  • \$\begingroup\$ Yes. I understand your reasons for the answers. But I am stuck with this line - The voltage at GPIO pin @ both the cases are the same 12V. So, why do we get different results. \$\endgroup\$
    – user220456
    Nov 17, 2020 at 15:21
  • \$\begingroup\$ The voltage is 5.77794 volts and not 12 volts. \$\endgroup\$
    Nov 17, 2020 at 15:27
No it isn't, in the second case the voltage is 5.7V.
The important thing to understand about resistance dividers is that they are not voltage regulators; with nothing else connected you achieve a specific voltage. When you connect something which draws current from the middle, then the current in the resistors is now different, and as a result they take on different voltage values.
It may become clearer if you try, for example:
  • measure the current at various points in the circuit. What current is travelling through each resistor? What current is through the diode?
  • putting a 1 ohm resistor between the "direct" supply and the pin. Vary this upwards - try 100R and 1K. This will reduce the voltage at the pin without explicitly having a resistor divider; the diode is effectively acting as the other "leg" of the divider.
