I am trying to create a D Flip Flop to use in a bidirectional 4-bit shift register, using Logisim. However, when using my D flip flop the shift register acts just as a normal register setting the bit for all 4 D flip-flops outputs instead of one by one. It works properly when using the D flip-flop provided by Logisim but I am wondering how to achieve this using my own D Flip-Flop.
This is the design of my D Flip Flop This is the design of my D Flip Flop
And this is the shift register (with the boxes representing the D Flip Flop) enter image description here
Any help would be greatly appreciated
    \$\begingroup\$ This is a latch, not a flip-flop. The output will keep following the input as long as the clock is high. A flip-flop will not do that. \$\endgroup\$ – user253751 Nov 18 '20 at 17:14
  • \$\begingroup\$ Unfortunately, there was no way to pass the clock output straight into the subcircuit so the latch was a workaround. \$\endgroup\$ – lilnut Nov 18 '20 at 17:40
  • \$\begingroup\$ what...........? \$\endgroup\$ – user253751 Nov 18 '20 at 17:51
D flip-flop provided by Logisim which you used for simulation was a positive edge-triggered D Flip-Flop. While what you have designed is a level-sensitive D latch.
You have to cascade two of those D latches in master-slave configuration to obtain a positive edge-triggered D Flip-Flop.
reference: Flip-Flops Wikipedia
    \$\begingroup\$ Thank you for your reply \$\endgroup\$ – lilnut Nov 18 '20 at 17:33
    \$\begingroup\$ @lilnut This is the answer that you should select because it explains the why part. \$\endgroup\$ – a concerned citizen Nov 18 '20 at 21:10
Shorten your clock pulse so that it is gone by the time the output data from one flip flop reaches the D input of the next. At the moment, with a long clock high time, when the new data arrives at a D input it is transferred straight through the flip flop and on to the next because the clock is still high.
This is a technique for producing a very short clock pulse, the duration of which is shorter than the time taken for the data to transition through the stage.
D type flip flop
    \$\begingroup\$ Unfortunately, even of you set the clock to Ton to 1 tick and Toff to 31 ticks, it still doesn't work. I suspect it calculates differently the states for the builtin D flip flop. \$\endgroup\$ – a concerned citizen Nov 18 '20 at 16:59
    \$\begingroup\$ @aconcernedcitizen yes, latches are different from flipflops. \$\endgroup\$ – user253751 Nov 18 '20 at 17:14
  • \$\begingroup\$ @user253751 True, but in real life you might get away with the inherent delays (also why you posted your answer). One of the reasons why I called it "concoction". \$\endgroup\$ – a concerned citizen Nov 18 '20 at 19:59
