Suppose supplier of NTC shut-down the production for the NTC series. In this case if I am unable to find exactly the same component but rather found close match (by comparing B value @ R25/R100), then what are the parameters I should look in the new component so that it can best fit in my project without any glitch.
I saw in the datasheet R-T curve and temperature coefficient of resistance (alpha). However, I could not understood how alpha values were derived. I made several attempts to calculate alpha based on (https://www.ametherm.com/thermistor/ntc-thermistor-calculating-the-temperature-coefficient-of-a-thermistor) but I failed to get values mentioned in datasheet (NCP03XH103J05RL).
I tried to plot R-T curve using given resistor value and tried to derive ADC value also and compared both but not sure if this is the correct way!
Example of NTC circuit:
