I am trying to design a voltage follower to drive a resistive load using MOSFET as a peripheral circuit. I am using this simple circuit using two NMOS transistors. The output is following the input. But the problem is output is becoming load-dependent. If I change the resistance of the load, I am getting an increase/decrease in output voltage. How can I solve this problem? Is there any CMOS based stable voltage follower/Unity gain buffer circuit which can be used to drive a resistive load?
    \$\begingroup\$ If you incorporate an op-amp and take feedback from Vout you can make it basically load independent. \$\endgroup\$
    – user57037
    Nov 20, 2020 at 22:08
  • \$\begingroup\$ @mkeith Thank you for your comment. I have area and power constraints so I cannot use op-amp. Are there any other ways or any other CMOS based circuits? \$\endgroup\$
    – Apprentice
    Nov 20, 2020 at 22:30
    \$\begingroup\$ If you can't use an opamp, then a single NPN will give better results than a single MOSFET. \$\endgroup\$
    – Mattman944
    Nov 20, 2020 at 23:58
  • \$\begingroup\$ @Mattman944 Thank you. I will check if this works. \$\endgroup\$
    – Apprentice
    Nov 22, 2020 at 20:54
You can use an op-amp to provide feedback control to mostly eliminate the load dependence:
In comments you said the reason you have not considered using an op-amp is "I have area and power constraints". But your proposed solution is to use a second MOSFET.
Very likely you can find an op-amp that uses just as little area and less power than any solution that involves adding a second MOSFET.
For example, Mouser lists 215 op-amps in SC70-5 package (2.0 x 1.25 mm), with typical supply current as low as 350 nA (and almost all below 1 mA). Other options are available in packages (mostly "wafer-level" and "chip-scale" types) smaller than 1 x 1 mm.
The best choice of op-amp will depend on the required bandwidth and Vdd voltage, which you haven't shared.
    \$\begingroup\$ Upvoted because I agree 100%. Packaged op-amps can be just as small as packaged transistors, because it is the package, not the die that is limiting size. I do suggest a series resistor to the gate, and a feedback capacitor from the op-amp output (which may not be needed, but...). \$\endgroup\$
    – user57037
    Nov 21, 2020 at 0:59
  • \$\begingroup\$ @mkeith, like so? \$\endgroup\$
    – The Photon
    Nov 21, 2020 at 1:02
  • \$\begingroup\$ Yeah but now that I see it I realize that the cap can't do much because vout will likely be low impedance. The cap will be "swamped". Maybe add a resistor between Vout and the bottom of the cap to allow it to have some effect. The concern is that the op-amp may not be stable if it takes its feedback from the transistor output. Taking some feedback directly from the op-amp output was intended to stabilize it (I mean that was my motivation). \$\endgroup\$
    – user57037
    Nov 21, 2020 at 1:05
  • \$\begingroup\$ @mkeith, careful, though. If we add too many extra parts OP's concerns about board area might start to gain some validity. \$\endgroup\$
    – The Photon
    Nov 21, 2020 at 1:07
  • \$\begingroup\$ Yes. Maybe better to just go to BJT instead of mosfet and get rid of the capacitor. I think the BJT will make a nicer load for the op-amp rather than the possibly high capacitance gate of the MOSFET. \$\endgroup\$
    – user57037
    Nov 21, 2020 at 1:41
