let's consider a simple dipole antenna of length L. The following picture refers to a half-wave dipole:
In general, at different frequencies, it's known that different modes are possible. Precisely, the open circuit at the end of the antenna forces the current to be zero at the antenna end points, which become null point of I(x) (current spatial wave).
Therefore, as shown in the following picture there may be:
- a half current wavelength along the dipole
- a whole current wavelength along the dipole
- 1.5 wavelength along the dipole
etc
Obviously, it's a discrete set of wavelengths that follow the equation: $$L=n\cdot\frac{\lambda}{2}$$
that means a discrete set of frequencies that follow the equation: $$f=n\cdot\frac{c}{2L}$$
with c = speed of light.
Therefore, only the following frequencies are possible: $$f=\frac{c}{2L},2\cdot\frac{c}{2L},3\cdot\frac{c}{2L},...$$
Well, what happens if the voltage source of the antenna (i.e. its signal supply) has a different frequency (for instance $$1.5\cdot\frac{c}{2L}$$)?
Such a voltage source forces the current (and voltage) frequency to be such intermediate frequency, but in theory the null points ad the end of the antenna can't allow that frequency to exist...
Which is the solution?
