Edit: As you can see in the comments, I got a great explanation about the pull-up resistor question. I also wanted to make more of a bullet point of the PNP question as follows:
When it comes to setting the current in a PNP circuit (like a current source or emitter follower), is the procedure the same as for NPN, i.e. base voltage determines emitter voltage (as long as Vee is high enough), which will be a diode drop higher that the base voltage, then the emitter resistor is chosen to set the current based on that and I=V/R? If so, why does the voltage stabilize at that level? It seems that Iec is bringing Ve down from Vee, but why would it stop at Vb+.6V? I could imagine the transistor constantly turning off and back on.
Original post:
I was really grateful for the answers to my last question and am hoping not to wear out my welcome by asking about everything I come across, but this question involves something that has confused me all along in reading this book, which is the logic of setting voltages and currents in transistor circuits, and another issue is what is meant by pull-up resistor in this context.
On pp. 74-75 (see attached image), the authors state that R3 in figure 2.23 is a pull-up resistor for Q1. First of all, I don't think they ever introduced the concept of a pull-up resistor in the foregoing, but putting that aside, I'm not sure how this is a pull-up resistor or why one is needed. I think I must not know what the term means -- when I look it up, the definitions usually have to do with logic levels and using resistors to tie a node to either ground or +5, and that makes sense to me. It doesn't seem as though there is any shortage of either voltage or current in that location, and although I see that Q2's base is drawing current from the emitter of Q1, it doesn't seem as though it would be enough to cause any deficiency. What am I missing?
Trying to understand that comment led me to think about how a PNP transistor circuit is set up and how often the logic seems confusing (to me). In the NPN circuits like the emitter follower and current source, the base voltage is supposed to set the emitter voltage, then the drop across the emitter resistor determines the current according to ohm's law as in figure 2.22 A and B. This seems to make sense, since the emitter should be at ground (in these examples) before voltage is applied to the base, and then the applied voltage overcomes the diode threshold voltage and the emitter is separated from ground by the resistor, allowing the voltage to rise to VB-.6V.
But in the PNP case (2.22 C), if there were no diodes or emitter resistor, the base and the emitter would be at +10V, and the transistor would be in cutoff. When the diodes are added, the transistor is biased and turns on -- what happens then? I guess the +10V on the emitter would cause the base voltage to rise until there is less than diode drop between them? And possibly destroy the transistor with a giant current through the base?
But when I look at the 560 Ohm resistor, I think, well, that would create a 1.2 Volt drop if the current were 2ma, OR it would produce a 2ma current if the voltage drop were 1.2V, but can it really set both values at once?
Now that I think of it, I guess that with no emitter resistor, once the transistor is on, a giant current flows to the collector, and that will destroy some components. But as long as there is any resistor on the emitter, the current flowing to the collector will cause the voltage to drop to VB +.6V, and that is how the voltage is set to allow the resistor value to be the determinant for the current. Does that sound right? And if so, why doesn't the voltage drop any further and cause the transistor to constantly turn on and off?
    \$\begingroup\$ You may need to break this discourse up into more bite-sized chunks. Figure out which question or two is probably most important to you. The answers to that may help you with the rest, anyway. So it may be a good idea to size this down. I can't seem to find a single concept or idea that would satisfy this, as it is. I'd have to write a similarly long discussion covering various ideas in various ways. And I may still miss the mark you are hoping for, incorrectly projecting my own guesses, because of the breadth of all this. \$\endgroup\$ – jonk Nov 21 at 20:41
    \$\begingroup\$ Just to address the "pull-up" part: I don't know if you understand a "current source" or "current sink" as an idealized concept, but the BJT collector (in active mode only, not saturated) is very much like a current source (PNP) or current sink (NPN.) These ideally have "infinite impedance." (In reality, obviously, not so much.) So the collector itself tends to be "disconnected." The pull-up resistor simply provides a known resistance to the collector and some voltage source. It's called "pull-up" in the NPN case because it pulls the collector towards the + rail. \$\endgroup\$ – jonk Nov 21 at 20:47
    \$\begingroup\$ So, in digital situations the shared end of the collector resistor is either "pulled-hard" towards its emitter or else "released to a floating condition" when it then needs a collector resistor to pull it to some specific voltage value (there's no current in the resistor, unloaded, so no drop across it and so it actually does pull almost all the way to the tied rail.) That's a "pull-up" or "pull-down" situation. In analog, the BJT collector is always a current source/sink, so infinite impedance all the time and the collector resistor still does pull, but that's not the point in analog. \$\endgroup\$ – jonk Nov 21 at 21:04
    \$\begingroup\$ In analog, it's about the voltage drop that is induced across the resistor by the current through the resistor. So it's not called a "pull-up" or "pull-down." Not because it's not performing that function. But instead because the important function is really the voltage drop across it. The resistor is converting the current into a voltage. And that's the more important idea, in these situations. So different names are used, instead. \$\endgroup\$ – jonk Nov 21 at 21:05
    \$\begingroup\$ There's a wonderful biography about Feynman, "The Beat of a Different Drum," by Jagdish Mehra. In it, there's a parable of sorts. But the summarized punchline would be something like, "You can know the name of things in all the languages in the world, but when you are finished, you'll know absolutely nothing whatever about anything. So let's look and study and observe and hypothesize and over time see how things really are, without words." Kind of like that, anyway. The gist is not to get lost in the words people use. Focus yourself upon learning behaviors. Then worry about words for them. \$\endgroup\$ – jonk Nov 21 at 21:14
