I've just received a set of speakers that I want to design an amplifier for.
Two of them are 5W 4Ω and one of them is 10W 8Ω.
How do I find the total peak power output of these? I apologize for such basic questions, I am new.
    \$\begingroup\$ What do you mean by "total peak power output" of those speakers, and why do you need it? \$\endgroup\$ – Justme Nov 21 '20 at 21:09
    \$\begingroup\$ mwhite22, the speaker ratings are probably average power values. If so, you can for short periods of time exceed it. But for conservative reasons, and also because most music will be listened to at about 1/5th or 1/6th the amplifier power rating, those power ratings are usually taken as peak power. It just gives a very comfortable safety margin that way. So you do NOT need to know the actual peak power for a speaker for some actual tiny, specified moment of time. I've never cared to know it. I suppose in extreme cases someone might need that info. But I'm hard-pressed to think of a good case. \$\endgroup\$ – jonk Nov 21 '20 at 21:22
    \$\begingroup\$ The total power is not relevant if you are going to use a stereo amplifier plus bass amp. Each speaker will be driven individually. \$\endgroup\$ – Transistor Nov 21 '20 at 21:33
I assume you have speaker elements (no cabinets) which are intended to be used without cross-over filters, they are not bass nor treble elements.
If we assume the 5W and 10W ratings are valid with the same signal content you can connect the 4 Ohm speakers in series and insert the 8 Ohm speaker in parallel with the series circuit. Then you have 4 Ohm load which hopefully stands 20W total input. Now you need a single amp which can output that 20W to 4 Ohm.
Speaker sellers unfortunately do not specify what the power rating exactly mean. There are some norms for it or the rating can be R.M.S but as well there can be said nothing else than a number of watts. This gives a possibility to write as high watts as needed for good looking ads as long as the photo of the product is plausible when compared to known speakers.
The watt rating principle is not the only unknown. The functionality of a speaker depends heavily on the cabinet, speakers convert electric power very differently to acoustic power and behave very differently as electric loads. Given 8 or 4 Ohm can actually be far from the truth because speakers are not resistors, they are electromechanical machines.
=> Constructions based only on given watts and ohms are gambling.
The gamble can be successful. I have built nearly the same combination for a guitarist. I put the speakers in the same cabinet which had open back wall. The guitarist liked the sound and that's that - well done! I guess nobody would stand the result if the signal was recorded classical music.
BTW. Test with a few volt battery to make the speakers to push air to the same direction.
