6
It's possible this question has been addressed, but I don't understand the terminology to know if it has. I have taken apart several of my older BNC-style home security cameras. What I'd like to do is take the infrared light board and power it up independently to be a supplement night light to the replacement cameras.
The top-right board is the back of the camera. The bottom-right is the back of the IR board. The bottom-left is the front of a different IR board, for perspective. My goal is to figure out how to wire up a 12v source (because that's what the power to the camera was) to just the IR board to have it stay on all the time. I'll plug it into an Zigbee compatible plug to control when it turns on and off.
But I have no idea which of those 4 leads are the positive and negative. Is there a way to tell (other than guessing), which ones are the power connectors?
Thanks!
  • 7
    \$\begingroup\$ Power on the lights, measure the voltages. \$\endgroup\$ Nov 23 '20 at 1:52
    \$\begingroup\$ Questions on the usage and modification of mystery products are not on topic. This site is reserved only for design questions and those where the asker has design-equivalent knowledge of the thing being asked about. Besides, you have three wires, not two, so likely the interface needs not only power but some sort of control signal. \$\endgroup\$ Nov 23 '20 at 2:16
    \$\begingroup\$ With all due respect, I read the tour page, and the "What types of questions should I avoid asking?" page. I see no reference to any 'design-equivalent knowledge' or 'mystery products' being off-topic.. And there are 4 wires. \$\endgroup\$ Nov 23 '20 at 2:35
  • \$\begingroup\$ 4 wires equals 6 voltage measurements ... what is stopping you from doing them? \$\endgroup\$
    – jsotola
    Nov 23 '20 at 3:19
    \$\begingroup\$ Measurement with power on as others suggest would be a good start. Using an oscilloscope would help even more. |||| 'mystery products' is not an official term but the concept of consumer equipment showing some input from OP re trouble shooting is. Generally, if someone can understand the problem/question well enough to provide a good technical answer (as has happened here) then I'd feel that the question was on topic enough. It's always a judgement call and Chris's comments are fair enough. (I'm meant to make decisions on such things - agh !! :-) ) \$\endgroup\$
    – Russell McMahon
    Nov 23 '20 at 11:45
7
The connector and the PCB itself gives some hints:
  1. The frontside of the IR-PCB(lower left in the picture) has a lot of LEDs exposed and one optically shielded from the other(down in the middle). This is an indicator that there is some measurement happening on a single IR LED and thus there is at least one wire carrying this signal.
  2. Another hint is the circuitry one the backside(lower right in the picture) of the IR-PCB. Down in the middle are some SMD components which look suspiciously like a switching regulator(one big coil, a diode, an IC and some small components)
  3. The connector on the frontside of the IR-PCB gives some additional information. First in most cases its common to put ground on Pin 1 of a connector. Pin 1 is indicated by a special solder pad(in this case square) or other special silkscreen markings(like the triangle next to "CN1" on the backside). In this case I'm not quite sure because we can clearly see a thick trace emerging from pin 1, which is uncommon because mostly ground is a solid copper pour all over the PCB. This could be a power trace.
  4. Looking further at the connector solder joints we can see another smaller trace emerging from pin 4 down under the LEDs. This could be some kind of signal. Pin 2 and 3 seem to be joined together and no clearly visible trace is emerging from them. This is an indicator for a ground connection, they could be connected to the copper pour.
So if these conclsions are right we got the following pinout:
Pin 1: Power Pin 2: GND/EN Pin 3: GND/EN Pin 4: SIG (Look on edit)
From a EMC standpoint its quite a good idea to have (analog) signal cable spatially seperated from a power line on which one end a switching power supply draws current and produces noise. Last but not least we can see a capacitor on pin 1 of the connector on the green PCB, which also indicates that this is a power line.
For further investigation I would suggest that you measure the traces with a multimeter. Maybe measure the resistance between pin 2 and 3, if its low the pins are connected. Then measure the resistance between the power socker on the camera and the pins on the connector. This should finally give you the right wiring information. No guarantuee that you can put 12V on the IR PCB, maybe its stepped down one the green PCB or elsewhere.
Hope my guesses and analysis of your PCBs could help.
Edit: As Passerby suggested there could be an enable pin for the converter. So maybe just Pin 2 or 3 are connected to ground and the other one is for enabling the converter. This means that you may need an additional signal to turn on the LEDs.
  • \$\begingroup\$ I'm betting there is an enable pin on the regulator circuit. \$\endgroup\$
    – Passerby
    Nov 23 '20 at 4:09
  • \$\begingroup\$ Jep. you're totally right. If they measure the ambient light with this single LED there must be a way to control the LEDs. Or the LED turns the regulator directly on and off. This could be the reason that they are so near to each other. \$\endgroup\$ Nov 23 '20 at 4:43
  • \$\begingroup\$ Nicely reasoned answer. MAY not be 100% right but a very good start (and may be wholly right :-) ). \$\endgroup\$
    – Russell McMahon
    Nov 23 '20 at 11:40
